#<holes> = 3 - Unexpected behaviour
2 years 2 months ago #308662 by phillc54
My bad...
Need to remove the ~ from the beginning of the second line:
cp /usr/share/doc/linuxcnc/examples/nc_files/plasmac/m_files/* ~/linuxcnc/nc_files/m_files/
2 years 2 months ago #308663 by CFE
No success Phil, I still get the M190 related error, see screenshot attached. I must admit I have never used sim configurations, so this is out of my depth :(
2 years 2 months ago #308665 by phillc54
No worries, this is distracting us from your main issue anyway.
I really don’t know what is going on with the velocity as it works fine here. I will have a play in the morning and see if anything odd happens.
The following user(s) said Thank You: CFE
2 years 2 months ago #308667 by CFE
Thank you Phil, I will have a deeper look here too.
2 years 2 months ago #308671 by CFE
I have attached a short video made with PEEK which shows the velocity increase at the last leg of the contour. Maybe this gives a bit more insight in the issue we're facing.
Cheers, Peter
2 years 2 months ago #308674 by phillc54
Could you open halmeter from a terminal and select the pin plasmac.feed-reduction and then do another video. It should change to 60 as it begins each fillet end return to 0 at the end of each fillet.
Time to create page: 0.464 seconds
