#<holes> = 3 - Unexpected behaviour
2 years 2 months ago #308652 by phillc54
Wow, I have not seen anything like that before, I have no clue...
Try this from a terminal:
linuxcnc /usr/share/doc/linuxcnc/examples/sample-configs/sim/qtplasmac/qtplasmac_l_metric.ini
2 years 2 months ago #308653 by CFE
Hi Phil,
Somehow I have a sim configuration, but it throws an error on opening, see image attached. Sorry, I have no experience with sim configurations at all :(
2 years 2 months ago #308654 by phillc54
Interestingly I made a sim from your config and it showed the same error but it did actually work. It also worked correctly on your gcode file.
Is it possible that your screen is "laggy" and does not update quick enough?
2 years 2 months ago #308655 by CFE
Hi Phil,
It seems having to do with missing "M190" and this section in the ini file :
[RS274NGC]
RS274NGC_STARTUP_CODE = G21 G40 G49 G80 G90 G92.1 G94 G97 M52P1
PARAMETER_FILE = metric_parameters.txt
SUBROUTINE_PATH = ./:../../nc_files
USER_M_PATH = ./:../../nc_files/plasmac/m_files
But that's as far as I can get ?
2 years 2 months ago #308658 by phillc54
There must be an issue with pathing differences between package installs and run in place installs...
Try this as a workaround from a terminal:
mkdir -p ~/linuxcnc/nc_files/m_files cp ~/usr/share/doc/linuxcnc/examples/nc_files/plasmac/m_files/* ~/linuxcnc/nc_files/m_files/
Then restart linuxcnc again.
2 years 2 months ago #308660 by CFE
Hi Phil,
I get this :
plasma@plasma:~$ mkdir -p ~/linuxcnc/nc_files/m_files
plasma@plasma:~$ cp ~/usr/share/doc/linuxcnc/examples/nc_files/plasmac/m_files/* ~/linuxcnc/nc_files/m_files/
cp: cannot stat '/home/plasma/usr/share/doc/linuxcnc/examples/nc_files/plasmac/m_files/*': No such file or directory
This is out of my territory I am afraid :(
Time to create page: 0.504 seconds
