#<holes> = 3 - Unexpected behaviour
2 years 2 months ago #308756 by CFE
Hi Phil,
I had a chance to make up a video with HAL Meter and the feed reduction stays at 60% except for the last leg.
Cheers, Peter
2 years 2 months ago #308757 by phillc54
The feed-reduction pin should be directly connected to motion.analog-out-03 which should be switched by the M67 E3 Qn g-code commands.
Could you look at motion.analog-out-03 with HAL Meter and see what it does.
They do change state correctly here.
The following user(s) said Thank You: CFE
2 years 2 months ago #308758 by CFE
Hi Phil,
Same result on the motion.analog-out-03 pin.
Cheers, Peter
2 years 2 months ago #308759 by phillc54
Hmmm, I don't understand what is going on. This is what you should see:
Warning: Spoiler!
It may be worth asking in a different forum section as a M67 issue, either Basic Configuration or Advanced Configuration as more folk will probably notice it. I am fairly certain that there is nothing we do which would affect M67 operations. In the meantime I will keep experimenting but not being able to replicate the issue makes it difficult.
2 years 2 months ago #308760 by CFE
Hi Phil,
Thank you. I checked the HAL pins and it looks like the feed reduction pin is connected to the motion pin. I will bring it up in advanced configuration, hopefully that gives us some clarity.
Love your work !
Cheers, Peter
2 years 2 months ago #308773 by phillc54
I am probably barking up the wrong tree but could you try with the following lines disabled in their respective files:
Plasma.ini:   HALFILE = plasma_gamepad.hal Plasma.hal:   loadusr -W hal_input -KRAL Gamepad
Time to create page: 0.177 seconds
