Servo Driver Plasma Retrofit
27 Jul 2025 17:02 #332432 by tommylight
Replied by tommylight on topic Servo Driver Plasma Retrofit
Is it possible to use stall force tolerance for z axis home and detecting the sheet metal in qtplasmac?
Yes for a DC motor, no (at least not easy at all) for steppers.
For a DC motor you would need a reed switch and wind some 5-10 times one of the motor cables around it (not both), wire the reed switch to any input and set it in hal as limit switch or probe.
The following user(s) said Thank You: kn612
27 Jul 2025 23:41 - 27 Jul 2025 23:42 #332450 by kn612
Replied by kn612 on topic Servo Driver Plasma Retrofit
File Name: HornetPlasma.hal
File Size:10 KB
File Name: HornetPlasma.ini
File Size:4 KB
In the hypertherm microedge software that currently controls the table has encoder polarity and dac polarity set to negative for one of the y axis and x axis.  Would I need to change the wiring I have going to the 7i97t to reflect that and would that be causing some of my issues?
Last edit: 27 Jul 2025 23:42 by kn612.
28 Jul 2025 00:27 #332452 by PCW
Replied by PCW on topic Servo Driver Plasma Retrofit
There is a basic setup error in the hal file: all PWMgens must be set to use offset mode
for the 7I97/7I97T. Here is an example from the basic7I97 configuration:
File Name: basic7i97.hal
File Size:11 KB
20 Nov 2025 01:46 #338765 by kn612
I don't see an option anywhere in pnnconf to set pwmgens to offset mode. Is that something I would have to manually add to hal?
Also what are some tuning settings to use for the servos to get started?
20 Nov 2025 16:54 #338806 by PCW
Yes, you would have to set it manually in HAL, something like:
setp hm2_7i97.0.pwmgen.00.offset-mode true
20 Nov 2025 17:08 #338809 by kn612
I am getting an error on startup after adding the lines about offset mode.  I attached error report and current hal.
Machine jogs around well.  Its when I hit the power button in qtplasmac that enables the motors that they move/jump a little bit.  Offset mode would  correct/dampen that I assume?
20 Nov 2025 17:43 #338815 by tommylight
At the very top of your hal file, there is some symbol that does not belong there, seem like '
20 Nov 2025 18:09 #338818 by kn612
You guys rock. Thank you so much for pointing that out. I was editing hal with libre office instead of text editor. Added the line about offset mode and now the servos are quiet and don't move or jump when enabled.
20 Nov 2025 20:28 #338829 by tommylight
You guys rock.
Not much lately, to old ! :)
You are welcomed, always.
And as a general rule, edit machine files only with simple text editors, anything else will add special characters to the files making a mess.
21 Nov 2025 01:43 #338844 by kn612
Great info as always. Thank you.
Setting up inputs now, getting an error on startup again related to inputs.  It states input pins do not exist.  Is this a common problem? Did I miss a simple step on configuring the 7i97t?
Time to create page: 0.137 seconds
