VTK Backplot on RPi 4
6 years 3 months ago #176389
by Nabazul
Replied by Nabazul on topic VTK Backplot on RPi 4
Alright i got to sucessfully install your deb package. The file was somewhat corrupted when i downloaded it with wget (was only 12 megs). Downloaded again wtih chromium and it installed successfully. Unfortunately i still get the "ImportError: No module named qt" Error. I guess i somewhere messed it up by manually compiling vtk. I will try again with a fresh install on a differend sd card and report back.
6 years 3 months ago - 6 years 3 months ago #176556
by Nabazul
Partial Success!
Started from scratch with the Raspberry PI OS (Desktop)
Installed the RT Kernel following this guide:
gnipsel.com/linuxcnc/uspace/rpi4-rt.html
Installed Linux CNC following this guide:
gnipsel.com/linuxcnc/uspace/rpi4-emc.html
Used scottas Guide to install vtk and qtpyvcp (btw wget failed everytime i tried it with that deb file)
Now i can launch linuxcnc with the Brender Action and Mini sim examples. I can also start up the Probe Basic GUI. However the vtk backplot is completely black. As soon as i do anything to manipulate the backplot linux cnc crashes with the following error:
To me this sounds like the end of the road on the raspi 4 as it reads like and hardware or driver problem....
EDIT: Googeling this error leads me to this:
discourse.vtk.org/t/error-glsl-1-50-is-not-supported/1444/2
So i guess i have to put "MESA_GL_VERSION_OVERRIDE=3.2" somewhere?
ERROR: In /home/pi/Development/VTK-8.2.0_old/Rendering/OpenGL2/vtkShaderProgram.cxx, line 447
vtkShaderProgram (0x29fc3e0): 0:1(10): error: GLSL 1.50 is not supported. Supported versions are: 1.10, 1.20, 1.00 ES, and 3.00 ES
Last edit: 6 years 3 months ago by Nabazul. Reason: Additional Info
6 years 3 months ago #176566
by scotta
Replied by scotta on topic VTK Backplot on RPi 4
I also had this error and went around and around with compilation options with no success. The issue for me was using the Full OpenGL kernel driver rather than the Legacy driver.
If you have a line like dtoverlay=vc4-kms-v3d in your config.txt try removing it. As I don't have a Pi 4 I cannot test directly.
For some reason the legacy driver supports newer versions of GLSL, or VTK is defaulting to OpenGL ES when the Full OpenGL driver is not available. I compiles VTK to support OpenGL ES. Not 100% sure, all a bit too complicated.
For me I cannot open Brender as the GL back plot is not supported on the Pi 3
BR
Scott
BR
Scott
6 years 3 months ago #176687
by Nabazul
6 years 2 months ago #180341
by persei8
Replied by persei8 on topic VTK Backplot on RPi 4
Are you guys using 32 or 64 bit buster? The install instructions for qtpyvcp state that it will not work on 32 bit os.
6 years 2 months ago #180357
by persei8
I got it working on raspberrypi os 32 bit buster but its slow and jerky. That might be because I'm connecting via ssh with x11 forwarding. I'll try a 64 bit os and see if it makes any difference. This might be a dumb question, but does anyone know if the vtk backplot can be used with qtvcp? The problem there is that the gcode_graphics widget uses opengl while the pi needs opengl es.
Time to create page: 0.066 seconds
