VTK Backplot on RPi 4
6 years 1 month ago #180439 by tommylight
Replied by tommylight on topic VTK Backplot on RPi 4
persei8 wrote: Yes it does. Maybe because it's a software implementation of opengl instead of using a GPU?
I think it was the other way round.
Does by any chance VTK use Vulcan as an rendering engine?
6 years 1 month ago #180465 by persei8
Replied by persei8 on topic VTK Backplot on RPi 4
No idea. I'm going to install the whole outfit on a laptop and see if I can sort any of this out. The vtk backplot works on the rpi with qtpyvcp so maybe it's possible to use vtk with qtvcp. If that turns out to be a huge project, then I give up because it is not my area of expertise.
6 years 1 month ago #180467 by tommylight
persei8 wrote: If that turns out to be a huge project, then I give up because it is not my area of expertise.
Knowing you, i am pretty sure you will do something about it. :)
6 years 1 month ago #180622 by scotta
Replied by scotta on topic VTK Backplot on RPi 4
I have some good news. After many many attempts to get OpenGL working with VTK back plot I have a working version.
VTK6.3.0 uses the legacy rendering backend. This would be the most compatible but I have not been able to build this against Qt5 at all.
VTK7.1 is now working with OpenGL legacy backend and works with both the fake and full OpenGL KMS drivers. Much smoother indeed.
I'm just in the process of working on VTK8.3 to enable GL ES functionality, hopefully this will fix some issues I have with a new widget for QtPyVCP which uses some OpenGL functionality that fails on the RPi.
I can share the updated deb package for VTK7.1.
Scott
The following user(s) said Thank You: KCJ, Aciera, pinder
6 years 1 month ago #180781 by scotta
I've published the new VTK7.1.1 deb package and updated instructions.
scottalford75.github.io/LinuxCNC-on-RPi/...20for%20QtPyVCP.html
Tested on RPi 3B and 3B+. Appreciate an RPi 4 tester.
Scott
The following user(s) said Thank You: TurBoss, pinder
6 years 1 month ago #181322 by persei8
So some further developments, here's a screenshot of Scott's new vtk package running on a RPi4 running qtvcp with a gcode file of over 280000 lines. It seems to run fairly well but I have more testing to do. It's weird that while I was porting the vtk backplot to run on qtvcp, it didn't show the gcode preview image, but it does on the pi. It was the same behaviour when running probe_basic so I don't think I broke anything. Anyway, it would appear we are making some headway in the Pi4 department.
The following user(s) said Thank You: cmorley, phillc54, KCJ, pinder
Moderators: KCJ, Lcvette
