MonoKrom - QtPyVCP GUI for PlasmaC and Mill
6 years 1 month ago - 6 years 1 month ago #184024 by pinder
we can also use this style to increase touch area
Last edit: 6 years 1 month ago by pinder.
The following user(s) said Thank You: AgentWD40
6 years 1 month ago #184025 by tommylight
pinder wrote: Just a little request.
Make monokrom in capitals
MONOKROM
cheers
Pinder
To late, i tend to disagree on this as all caps is considered screaming on the internet.
But it has already been decided so i will shut up now ! :)
6 years 1 month ago - 6 years 1 month ago #184029 by AgentWD40
pinder wrote: changing colors wont do any good because that will be under your fingertip and you wont be able to see that.
And trust me I got pretty big hand and fat fingers, there wont be any problem. Moreover, you can get 24inch touchscreen for cheap, and you will be happy for that.
I meant to momentarily change the color of the *whole* control. The yellow background of the numbers might flash green for + and red for -.
what custom buttons you want?
Current plasmac axis and gmoccapy UI's allow for 5 and 4 custom user buttons respectively. In my own case I have a button that runs a series of gcode commands to send my gantry to a defined "parking spot" in a particular manner. I'm sure I'll come up with more for my machine. I have another non-linuxcnc cnc router that uses cnc.js, with it I've got about a dozen custom one click "macros" that I use...
Last edit: 6 years 1 month ago by AgentWD40.
6 years 1 month ago #184030 by pinder
MONOKROM
cheers
Pinder
Still, your opinion is registered.
Its somewhat personal taste.
6 years 1 month ago #184033 by pinder
AgentWD40 wrote: momentarily change the color of the *whole* control. The yellow background of the numbers might flash green for + and red for -.
Now I got you. But staying monochromatic is a challenge, adding more colors is out of bounds. I hope Kurt will be able to add some kind of feedback to let you know that values are changing.
AgentWD40 wrote: Current plasmac axis and gmoccapy UI's allow for 5 and 4 custom user buttons respectively. In my own case I have a button that runs a series of gcode commands to send my gantry to a defined "parking spot" in a particular manner.
We can surely manage a new tab for that.
But adding those to main screen would be a clutter.
I will add a tab at the bottom for all these misc. things.
6 years 1 month ago #184035 by pinder
This is updated svg zip for all panels
File Name: output.zip
File Size:346.62 KB
The following user(s) said Thank You: tommylight, Clive S, KCJ
Moderators: KCJ, Lcvette
Time to create page: 0.346 seconds
