- Thank you received: 128
thankyou Kurt,KCJ wrote: Done, will use MONOKROM for all typography.
Package names and commands will stay lowercase, of course
NoAgentWD40 wrote: Sorry I'm not able to download this and see for myself before I ask.. Do the buttons have a different color when pressed?
changing colors wont do any good because that will be under your fingertip and you wont be able to see that.AgentWD40 wrote: Im just thinking about mashing a touchscreen with fat fingers, it might be nice for the + and - buttons to flash the control green and red respectively when pressing the "kerf width" control for example.
Only Kurt can answer thatAgentWD40 wrote:
If you press and hold + or - will the number cycle up or down as long as you hold or does it only increment once per tap? I assume that holding wouldn't be practical for some controls. What's the increment value? Will the increment value be end user adjustable in a config?
what custom buttons you want?AgentWD40 wrote: Finally, will there be room for me to add my own buttons somewhere? At least a couple on the main screen?
