- Thank you received: 267
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
- KCJ
pinder wrote: Need some beutification.
shouldn't there be a back previous folder option
like ../
That is just a standard FileView I used for filler.
What I was actually trying to show was the modal dialog implementation that greys out the background window. It has a custom frame so it matches the rest of the UI. It's a lot more work, but a native window border on the modal dialogs would ruin the clean look the the GUI.
Cheers,
Kurt
- pinder
- Thank you received: 128
I didn't know how much effort it took.
I tried qt designer, but not been able to completely grab it.
Thankyou for you time and effort.
Cheers,
Pinder.
- CBEAR
- Thank you received: 46
Here's a picture of an nc-ish brake that I built a couple of years ago out of 95% repurposed materials. Including the readout, the stepper driven backgauge with adjustable speed, and my tooling, I think I'm into it right around $1,000 USD. I got the electric/hydraulic unit from a shop that was scrapping an old hoist for $40. The cylinder was given to me, 95% of the steel was purchased from someone for $100. The most expensive piece was the casters at $120 USD:) It ends up creating right around 37 tons of pressure. It has worked alright for what I needed it to, but I am planning on importing an 80 ton 1600mm cnc in the next year.
- KCJ
Based on the scale it's about 6" long??
I have seen quite a few homemade press brakes, some very ingenious. We have one customer that bought a 1.6 million automated folder to replace a 60yr old homemade press brake for making stainless food service sinks. Both machines make the same sink tub in the same amount of time, but it takes a lot more skill to make it on the brake.
- Thank you received: 7491
Looks a bit bigger to me, but i do wear glasses!KCJ wrote: Based on the scale it's about 6" long??
- pinder
I think I need some help in doing these.
Instructional images is needed?
Preview window should be included with current toolpath?
Buttons?
Don't we need go to zero button?
Moreover, can anyone send some kind of alarm or warning windows example or idea?
SVG
