MonoKrom - QtPyVCP GUI for PlasmaC and Mill
6 years 1 month ago - 6 years 1 month ago #184348 by pinder
Replied by pinder on topic MonoKrom - QtPyVCP GUI for PlasmaC
Statistics panel done;
I'll get some hands-on with qt designer.
I think option of exporting stat data to csv or other suitable format would be excellent for some people, even importing it will help in some cases.
if it is stored in csv, then i thin it will be pretty simple.
svg is in the zip
File Name: Web192010.zip
File Size:5 KB
Last edit: 6 years 1 month ago by pinder.
6 years 1 month ago - 6 years 1 month ago #184355 by pinder
I am hoping that we could add camera panel which @phillC54 showed in his thread.
@phillc54 what other buttons would be needed for this panel to work?
If people think that this is more important, then we could add a main tab for this other than settings
6 years 1 month ago - 6 years 1 month ago #184371 by KCJ
Replied by KCJ on topic MonoKrom - QtPyVCP GUI for PlasmaC
Looks good!
A camera panel is a requirement I think. And is easy to add from a programing point of view, so there is no reason not to.
I made great ptoy on reading and writing the run setting last night. I'll post when I get home from work this evening.
Pinder, can you wip up a simple design for a splash screen witth loading progress indicator? I'm no good at design...
Cheers,
Kurt
Last edit: 6 years 1 month ago by KCJ.
The following user(s) said Thank You: pinder
6 years 1 month ago #184372 by pinder
KCJ wrote: Looks good!
Cheers,
Kurt
Sure
The following user(s) said Thank You: KCJ
6 years 1 month ago #184373 by rodw
Replied by rodw on topic MonoKrom - QtPyVCP GUI for PlasmaC
I'm not really convinced plasma is a good candidate for a USB camera. The maximum USB cable length is about 5.0 metres in the spec and I have first hand experience with failed USB links around that length (After I had cut the end off and passed it through the firewall of a vehicle.... then I had to rework it to add a powered hub under the dash, cut the end off and redo it! powering a 5V hub in a 12v vehicle is not fun!)
I found a premade 5.0m serial cable was not long enough to reach my Z axis control box on a 1200 x 1200 mm table.
So how would you go with a 1200 x 2400 or 1500 x 3000mm table?
Sure you can get USB extenders, I just saw an ethernet cable extender that cost AUD $629. You can get active cables often used in photo studios.
The other thing is that we do not need pixel peeping accuracy because good enough is near enough because a sheet of steel is typically slightly oversize.
A button for a laser pointer touch off is more practical I think.
6 years 1 month ago - 6 years 1 month ago #184374 by pinder
rodw wrote: I'm not really convinced plasma is a good candidate for a USB camera. The maximum USB cable length is about 5.0 metres in the spec and I have first hand experience with failed USB links around that length (After I had cut the end off and passed it through the firewall of a vehicle.... then I had to rework it to add a powered hub under the dash, cut the end off and redo it! powering a 5V hub in a 12v vehicle is not fun!)
Powered USB usbs are cheapest to buy.
Simplest soution is power Use
5V regulator LM7805 with any 12v power supply is the cheapest option,
moreover you can use copletely separate USB charging adapter.
If phill's plugin is working correctly. Would be great to have.
Otherwise just a black screen.
Moderators: KCJ, Lcvette
Time to create page: 2.160 seconds
