- Thank you received: 96
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
- AgentWD40
pinder wrote:
AgentWD40 wrote: @pinder, I don't know if it was your intention but you've just about talked me into getting a touchscreen monitor :laugh:
You mentioned earlier you're designing around a 1366x768 resolution. What's a comfortable minimum size for a touchscreen?
i think minimum would be 1366x768
or you can get capacitive touch panels from aliexpress/ebay for monitors
between 50-80$
you can add get good quality touchscreen from amazon for 190$
What I meant to ask what's the smallest physical screen size that's comfortable to use?
- pinder
- Thank you received: 128
Dont go below 10 inches(these are readily available as touchscreen)AgentWD40 wrote: What I meant to ask what's the smallest physical screen size that's comfortable to use?
ideal would be 15inches
- pinder
- Thank you received: 4153
I also think 15" should be nice. I recently purchased an Asus VT168H 15" touch screen which is nice. Native resolution is 1366 x 768. Only issue is its a capacitive screen so not usable with work gloves. It is very nice size mounted in an enclosure with an Odroid H2+
See www.asus.com/au/Monitors/VT168H/
Thats my plan for this when you guys are done..
pinder wrote: as I asked earlier.
Default and only option to open gcode files should be USB, and no-one said anything.
Should I assume it is Ok.
This in view that user should get smooth experience. Like OEM solutions.
Network location can also be an option.
Pleas do not restrict what file locations can be opened. Linuxcnc has a default file location which needs to be supported but we might want to substitute a network location or a USB drive. Ideally, save the last location opened and use that until you navigate to another location..
- Thank you received: 7491
+1rodw wrote: Pleas do not restrict what file locations can be opened. Linuxcnc has a default file location which needs to be supported but we might want to substitute a network location or a USB drive. Ideally, save the last location opened and use that until you navigate to another location..
