- Thank you received: 4153
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
or we can place a popup[/quote]pinder wrote: @AgentWD40, @rodw Check if thats all right
@pinder , looks great . My idea was not to over power the screen with too much data and that does it perfectly.
I don't think a popup wolud work as nice.
KCJ wrote: This evening's progress.
Got the of the DROs functional and homing working.
The DROs are automatically added to suit the axes configured in the INI.
@rodw Type in DRO to define current position just for you
The design is growing on me as I bring it to life.
At this point I'm just trying to get close to what you have mocked up, will worry about matching font sizes etc. exactly later.
Cheers,
Kurt
Kurt, looks perfect thanks. I knew you could do it!
You guys are really powering ahead. I'm loving the no nonsense approach where feedback is evaluated and incorporated at warp speed.
I did a bit of research on best practice HMI's for both industry and CNC. Boring monochrome is good. Just use colour to highlight exceptions. At first the yellow did not do it for me either but as you say when you see it come together, it grows on you!
- pinder
- Thank you received: 128
Kurt is doing a great job here.
This is my inspiration
- AgentWD40
- Thank you received: 96
You mentioned earlier you're designing around a 1366x768 resolution. What's a comfortable minimum size for a touchscreen?
- pinder
AgentWD40 wrote: @pinder, I don't know if it was your intention but you've just about talked me into getting a touchscreen monitor :laugh:
i think minimum would be 1366x768
or you can get capacitive touch panels from aliexpress/ebay for monitors
between 50-80$
you can add get good quality touchscreen from amazon for 190$
- pinder
Default and only option to open gcode files should be USB, and no-one said anything.
Should I assume it is Ok.
This in view that user should get smooth experience. Like OEM solutions.
Network location can also be an option.
- Thank you received: 7491
Not ideal but i can live with that.pinder wrote: as I asked earlier.
