electronic tool setter, tool touch off process
5 years 9 months ago - 5 years 9 months ago #195791 by swalts
oh Dang!
Will this populate automatically when the sensor triggers?
Will the process look like this.
1. Load tool zero
2. touch off tool (spindle nose)
3. spindle zero (circled above) is now populated
Thanks for the picture. making the jump from Mach to Linuxcnc has been a humbling adventure.
I really appreciate all the help.
Last edit: 5 years 9 months ago by swalts.
5 years 9 months ago #195792 by Lcvette
no, you need to manually enter the spindle zero, record the number as positive, ie if the dro reads -12.375" record spindle zero height as 12.375. then it should work as intended!
5 years 9 months ago #195793 by swalts
this may be an elementary question, but.
How will i know when the tool setter has tripped? It has no external indicator on it. If i use hal show, then i will not be able to move the axis.
Not sure what i am missing.
5 years 9 months ago #195794 by Lcvette
you can use the probing process for z, it records a probed point. just change the probe number in the probe setting to your spindle nose tool number and probe z and record the value that the probe event gives you.
5 years 9 months ago #195796 by swalts
AH! nice!
I am typing out a step by step now. Will copy/paste shortly.
Thank you Lcvette, I appreciate your time.
5 years 9 months ago #195798 by swalts
This is my current understanding of the process. Please correct me if i am wrong.
TOOL LENGTH OFFSET PROCESS
POST WORK PIECE PROBING
probe work piece
SETTING REFERENCE TOOL
1. Load tool 00 for spindle nose.
2. use z probe routine to find z offset value
3. manually enter probed length (as positive value) in the "SPINDLE ZERO" box
4. Load tool# to be used on material.
5. Probe Z routine
6. Cycle start
Thanks again.
Moderators: KCJ, Lcvette
Time to create page: 0.348 seconds
