(SOLVED!!!) Probe Basic - rotary axis jogging
- TurBoss
- Thank you received: 81
31 Oct 2021 15:22 - 31 Oct 2021 15:23 #224773
by TurBoss
Replied by TurBoss on topic Probe Basic - rotary axis jogging
hello
you can just delete that line
github.com/kcjengr/probe_basic/blob/master/setup.py#L24
if you have qtpyvcp in a directory called develop (doesn't matter)
probe_basic python3
and qtpyvcp.conversational python3
and run
probe_basic python3
and run
cd ~/develop/qtpyvcp/
python3 -m pip install -e .
qcompile .
cd ../probe_basic
git checkout python3
qcompile .
Last edit: 31 Oct 2021 15:23 by TurBoss.
- spumco
- Thank you received: 798
31 Oct 2021 15:54 #224777
by spumco
Replied by spumco on topic Probe Basic - rotary axis jogging
It's already installed and appears to be working ok, I shouldn't need to reinstall everything, do I?
If not, and the change you suggested is just for installation, you might suggest to Spi in his thread "Definitive guide to installation" that he can update his instructions accordingly.
- TurBoss
31 Oct 2021 16:02 #224778
by TurBoss
oh you right
i miss-understood your post
- spumco
01 Nov 2021 03:54 - 01 Nov 2021 04:20 #224830
by spumco
Had a go at this a minute ago and got an error.
LCNC reported that qtpyvcp.machine.jog.set-angular-speed-percentage-enable exceeded maximum number of characters (47)
Still a little fuzzy on the architechture - will the new machine action be an exported hal pin I can link in my hal file, or is it slaved to the existing linear slider inside probe_basic.ui inside QT Designer?
-Ralph
EDIT - I used "HAL slider" instead of "VCP slider", so that's sorted out now.
Next hurdle... I've got a new slider on the screen as I wasn't sure how to hide it and it isn't slaved to the linear jog percentage slider. Not a problem at the moment.
Under the slider settingName field I entered machine.jog.set-angular-speed-percentage.
The issue is that it doesn't appear to be doing anything. I can slide it back and forth, but it doesn't change my angular axis speed using the screen jog buttons. Same response as before I did the git pull - feedrate display jumps to '100' and doesn't change regardless of the slider position.
I have both angular velocity settings my INI file as mentioned above.
Any idea what I've done wrong?
qtpyvcp master branch now has support or a new machine action:
machine.jog.set-angular-speed-percentage If you use an action slide with this action it will perform in the same manner as the linear version. In the case of Probe Basic you can add a hidden slide with this action and using signals from the existing slider have the hidden one slaved off the existing linear. This means moving that single slider will drive the % of jog against the MAX_ANGULAR_VELOCITY and MAX_LINEAR_VELOCITY as set in the config INI file. For angular axis you should be setting DEFAULT_ANGUALR_VELOCITY and MAX_ANGULAR_VELOCITY in the config ini. Cheers - James.
-Ralph
Last edit: 01 Nov 2021 04:20 by spumco.
- Joco
- Thank you received: 326
01 Nov 2021 06:30 #224843
by Joco
Replied by Joco on topic Probe Basic - rotary axis jogging
The slider to be used is: ActionSlider
There should be a field in propert editor under the ActionSlider section called: actionName. Place your "machine.jog.set-angular-speed-percentage" text there.
Also remember to set the objectName to something meaningful.
Create a signal with:
Sender: select object name of master action slider
Signal: ValueChanged(int)
Receiver: objeect name of slave action slider
Slot: SetValue(int)
While I have no 4th axis I can see the machine angular speed and linear speeds being changed at the software level.
To hide it gets a little more fiddly. That might need to be done using some python code in the main UI python module. Unless I can figure out a stylesheet setting that will hide it.
Slot: SetValue(int)
- spumco
03 Nov 2021 02:36 #225065
by spumco
James,
Finally got around to trying this again - no dice.
I created an action slider and slaved it to the existing jog slider. That worked just fine, and the linear axis jog speed still changes appropriately. But the angular speed does not change, and I got an error during startup stating:
type object 'jog' has no attribute 'set_angular_speed_percentage'
Does this mean when I did the git pull that the updated (new) machine function isn't present?
- Joco
03 Nov 2021 03:28 - 03 Nov 2021 03:29 #225070
by Joco
that looks to me like you have not got the latest version down yet. So in the qtpyvcp directory:
To check you have the right version is in the file: qtpyvcp/actions/machine_actions.py
look at lines 905 to 916, there will be function and setting references to things like 'machine.jog.angular-speed-percentage' and similar.
Cheers - James.
git pullTo check you have the right version is in the file: qtpyvcp/actions/machine_actions.py
Cheers - James.
Last edit: 03 Nov 2021 03:29 by Joco.
- spumco
03 Nov 2021 11:35 #225092
by spumco
I don't think that was it. I just checked and I've got this in machine_actions.py:
@setting('machine.jog.angular-speed-percentage',
default_value=int(DEFAULT_JOG_ANGULAR_SPEED * 100 / MAX_JOG_ANGULAR_SPEED),
min_value=0,
max_value=100,
persistent=False)
def jog_angular_speed_percentage(obj):
return obj.value
Maybe my INI file needs a DEFAULT_JOG_ANGULAR_SPEED and MAX_JOG_ANGULAR_SPEED statement in it?
min_value=0,
max_value=100,
persistent=False)
return obj.value
- Joco
03 Nov 2021 17:24 #225121
by Joco
For some reason I thought you had done that. Yes you need those defaults.
- spumco
04 Nov 2021 01:18 #225182
by spumco
Still no dice.
I tried putting the INI statements in both the [TRAJ] section and [DISPLAY] where some other velocity settings are.
Same outcome - same qtpyvcp error (type object 'jog' has no attribute 'set_angular_speed_percentage'), and the on-screen A-axis jog button jogs at '100' no matter where the slider(s) are.
And PB is using the max angular velocity in my INI file (100), but it (still) appears to be interpreting/commanding in degrees per minute - not per second.
Unless I'm reading the LCNC docs wrong, all velocity statements in the INI file are in machine units per second, right?
Moderators: KCJ, Lcvette
Time to create page: 0.078 seconds
