Probe Basic Rack based ATC
- udoS
- Thank you received: 25
17 Nov 2023 21:47 #285782
by udoS
Replied by udoS on topic Probe Basic Rack based ATC
- P1-Engineering
- Thank you received: 8
18 Nov 2023 11:17 #285817
by P1-Engineering
Replied by P1-Engineering on topic Probe Basic Rack based ATC
I didn't make any progress. Beginning of the year I made the decision to just go all-in and purchase a professional VMC with Siemens control and haven't looked back.
Still want to complete my Linux system one day because it can be interesting to upgrade an older VMC to Linux as a support machine. But for now just busy making chips 7 days a week
- P1-Engineering
18 Nov 2023 11:20 - 18 Nov 2023 11:21 #285818
by P1-Engineering
xxxx
Last edit: 18 Nov 2023 11:21 by P1-Engineering. Reason: forgot the quote
- P1-Engineering
18 Nov 2023 11:22 #285819
by P1-Engineering
I see you have a Sorotec machine. What I did is buy the Sorotec ATC macro for EdingCNC. This works 100% perfect with all the features you want. My plan was to convert this to Linux which should be fairly straight forward, just a matter of remapping the variables and commands to control various inputs and outputs. If you bought the machine from them you can get the macro for around €100 I believe.
Back to the Problem that is not solved for years ! ( that's what it looks like )
SetUp : Mill
x-axis : 410 mmy-axis : 520 mmz-axis : 110 mm
home at : x0 y520 z110 ( left back top )
SetUp : ATC-Spindel
put air-pressure : drop_tool;
release air-pressure : pull_tool;
SetUp : Tool-Changer
Horizontal rack along x-axis at y520 with n-positions;
SetUp : Tool-Length-Sensor :
Tool-change Position at x385 y380 z110;
Trigger at x385 y380 z41.4145;
For the tool-change with PB I have 4 CASE plus some subCASE for each :
CASE_1.) change tool in auto-mode with G-Code in program : T5 M6 G43
CASE_2.) change tool in mdi-mode with G_Code in command-line : T5 M6 G43
CASE_3.) change tool by insert new tool-number (5) in PB and press button( M6 G43)
CASE_4.) change tool by hand at G30 ( and do, or do not touch-off )
So where do I get started
- udoS
18 Nov 2023 11:44 - 18 Nov 2023 11:51 #285821
by udoS
@P1-Engineering
May I ask where you are located ?
About the macros : I'm at LinuxCNC & EtherCAT;
Since I'm at it I want a setup for the ATC-rack and TLS with Probe-Basic as the GUI;
L.G.
L.G.
Last edit: 18 Nov 2023 11:51 by udoS.
- P1-Engineering
18 Nov 2023 11:50 #285823
by P1-Engineering
Netherlands
- rmu
- Thank you received: 101
18 Nov 2023 22:47 #285865
by rmu
Replied by rmu on topic Probe Basic Rack based ATC
what is the problem@rmu
nice .. spanische Dörfer;
- udoS
19 Nov 2023 22:04 #285959
by udoS
@rmu
the problem : Step by step from T2 M6 to cnc starts the correct ... macro ... for starters, please.
< what code, in what file and where is the file located; >
sorry.
L.G
sorry.
L.G
- dpslwk
- Thank you received: 15
19 Nov 2023 22:47 #285965
by dpslwk
Replied by dpslwk on topic Probe Basic Rack based ATC
maybe start by reading
linuxcnc.org/docs/2.9/html/remap/remap.html
And see the INI entries mentioned over at
forum.linuxcnc.org/qtpyvcp/48401-py3-pro...version-doc-lcnc-2-9
where there are a bunch of commented out lines (#) that are uncommented if you wish to use the probe basic carrousel style ATC tab and included subroutines
but to build a Rack / linear ATC you will want to ignore the existing bits in PB and the above config and build you own M6 remap
a few example of a rack m6 remap have already been pointed out
and I found this one too github.com/GuiHue/myfenjalinuxcnc/blob/m...cros/rack_change.ngc
- dpslwk
19 Nov 2023 22:51 #285966
by dpslwk
based on
"home at : x0 y520 z110 ( left back top )"
you seem to have your machine Z0 at the bottom of the travel (bed height) and the axis going positive from there,
most have Z0 at the top of the travel and going negative towards the bed
lot of existing examples code with be expecting Zo at the top, where a move to Z0 is consider safe (by moving tool all the way up)
Moderators: KCJ, Lcvette
Time to create page: 0.157 seconds
