Rotary Jog low
3 years 9 months ago #262501 by CNC_ANDI
Replied by CNC_ANDI on topic Rotary Jog low
hello, today i was trying to install Probe_basic under Debain 11 on a other PC...
i was following this manual
www.qtpyvcp.com/install/bullseye.html
but at this part
dpkg-buildpackage -b -uc
i got errors
how can i install po4a 0.66?
did you have a complete manual for this installation?
3 years 9 months ago #262519 by Lcvette
Replied by Lcvette on topic Rotary Jog low
I use the script installer found here, it is much esdier and just works:
github.com/joco-nz/lcnc-bullseye-installer
this will install everything you need, linuxcnc, qtpyvcp and probe basic as well as the correct realtime kernel.
follow the instructions to the letter and use Debian Bullseye 11 xfce4 non free and should go on without a hitch. the other instructions often have missing dependencies because things are ever changing so its hard to keep the instructions current.
3 years 9 months ago #262527 by CNC_ANDI
hi, thanks i have installed the debian-live-11.6.0-amd64-xfce+nonfree.iso
and followed your link. linuxcnc axis runs but i cant find the probe basic screen.
when im running opengl test i become an error with No module named 'minigl'
3 years 9 months ago #262536 by Lcvette
You would have made a folder named dev, in that folder is the probe basic folder and their is a config folder, copy it over to the linuxcnc config folder. Then look for the sim in the drop down as your were doing previously. You should be able to run the sim and make sure severity looks good.
Then once you've got that working, you can start converting your old configs over. Hoping to have a doc finished up by end of the weekend, got side tracked looking into a config builder for probe basic.
3 years 9 months ago #262564 by CNC_ANDI
Got the probe_basic screen...
Today i will check the config.
3 years 9 months ago #262566 by CNC_ANDI
ok got it work today....
so the dro displays dont work correctly. i´ve changed the number to 2 for 5 axis display, got work but when i close linuxcnc an reopen again des display changes ro 3 axis but the number 2 for 5 axis display was saved. now i most change the number an back again to get the 5 axis display.
Moderators: KCJ, Lcvette
Time to create page: 0.095 seconds
