Rotary Jog low
3 years 9 months ago #262595 by CNC_ANDI
Replied by CNC_ANDI on topic Rotary Jog low
editvcp probe_basic dont work....
but with the installer i selected developer install.. hmm.
tomorrow i will try the updater.sh
3 years 9 months ago - 3 years 9 months ago #262747 by Lcvette
Replied by Lcvette on topic Rotary Jog low
did you get it sorted out?  if not, can you send any errors that you saw during install and or when trying to run editvcp!
Last edit: 3 years 9 months ago by Lcvette.
The following user(s) said Thank You: CNC_ANDI
3 years 9 months ago - 3 years 9 months ago #262758 by CNC_ANDI
Hi, today i got editvcp to run.So i have changed the value from 0 to 1 for the 4 axis display and deselect encoder for spindle rpm and selected the other one.i changed at 4 axis display all a (for A Axis) to b (B Axis) to got a xyzb display....so will it work? Or i have to do more changes?Here are my
changes:
By the way... i've tryed to update linuxcnc-uspace from 2.10 pre0 to the latest pre... but got this error...
Last edit: 3 years 9 months ago by CNC_ANDI.
3 years 9 months ago #262771 by Lcvette
im not sure why you were changing all of that? to display the 4 axis dro page all you needed to do was click the stacked widget tab arrow to display the 4 axis dro page and then save the ui from the file drop down menu, it will then default to the 4 axis display. no need to change anything else. i would go back and undo those changes and follow the instruction above.
as for the update, you should be running 2.9 not 2.10, 2.9 is pretty close to be a lockdown version, 2.10 is not. it will have issues going forward most likely that will require compatibility bug fixes that you will not be able to access.
3 years 9 months ago #262774 by CNC_ANDI
Hello thanks i will see how i can down to 2.9.
The standart dro is xyza. But i need xyzb.
I've made backup from the original ui so i can change back.
3 years 9 months ago #262776 by Lcvette
ah, ok.. sorry thought you were adding in new dro's..lol yeah thats fine!
Moderators: KCJ, Lcvette
Time to create page: 0.063 seconds
