Rotary Jog low
3 years 9 months ago - 3 years 9 months ago #262265 by CNC_ANDI
Replied by CNC_ANDI on topic Rotary Jog low
Here is my ini file. You can see the rotary velocity an acclereations.
File Name: CNC-ANDI_2....ini.txt
File Size:8.37 KB
So how can i get this slider?
Can you tell me how can i do this or did you have a manual for that?
Last edit: 3 years 9 months ago by CNC_ANDI.
3 years 9 months ago #262267 by Lcvette
Replied by Lcvette on topic Rotary Jog low
File Size:8.37 KB
it is in the latest version of probe basic in the py3 version.  what version of linuxcnc and probe basic are you using?
3 years 9 months ago #262276 by Lcvette
ok just saw you are on linuxcnc 2.8 which is the old py2 version. that version is no longer updatable, our hands are tied because changing anything in the current installer would break it and require dependencies that are no longer available. so we had to move over to the latest python3 version of linuxcnc to continue development.
however, you can install the py2 dev version, and you can still make changes to your own local interface without worry.
the better option would be to move up to linuxcnc 2.9 on on a Debian 11 bullseye install, and the latest version of probe basic which is updated as needed still. from there you could pull any updates from git as required, and in the near future once linuxcnc 2.9 stable is released there will be an installer available for the latest Probe basic with an updater for easier version release updates. unfortunately it is all still hinging on linuxcnc release arriving for that last part to happen.
3 years 9 months ago - 3 years 9 months ago #262324 by CNC_ANDI
I think linuc cnc 2.8.4.... and have installed the probe basic from the website with the installer since 09-2022
I will check it.
Edit: Ok thanks than i will wait for the stable version before i reinstall my system....
3 years 9 months ago #262368 by CNC_ANDI
when i get install the new Probe_basic can i use my actually ini for the new one too?
3 years 9 months ago #262427 by Lcvette
if you have a current working config, it will require some editing for the py3 version of probe basic to accommodate some of the new functionality in the update interface, I am in the process of making a py2 to py3 transition document for configuration files that should make it pretty simple.
Moderators: KCJ, Lcvette
Time to create page: 0.603 seconds
