- Thank you received: 81
I am doing a test run in a virtualbox vm before I do a real install on my linuxcnc box, since it's currently working well on axis from the linux.org 2.9 install.- What Linux OS being used including kernel type?
- What version of Linuxcnc is installed?
- What version of QtPyVCP and Probe Basic is installed?
kcjengr.github.io/probe_basic/quick_start.html- How did you install Probe Basic? Quickstart guide? Dev Guide?
Does not apply- Have you gone through your ini and hal files and compared to the sim config files to make any changes needed?
- Have you added all of the necessary files in your config folder that probe basic needs to run?
- Have you tested the sim version to see if the problem exists there also? (if the sim functions properly, it is a good indicator your issue is in your config)
