User Install for Probe Basic Py3 (For Machine Control)
3 years 6 months ago #270267 by ihavenofish
wooo
seems to have worked. in addition t the ui, i think something was wrong with python last time. this time it gave me an error and told me to fix instal. after that it took a while to do various things, which it definitely didnt do before.
So the next thing is the config. am i right in that other pinned post is the instructions (something about merging the sim into the pncconf generated config?
3 years 6 months ago #270269 by Lcvette
read thoroughly the instructions here:
forum.linuxcnc.org/qtpyvcp/48401-configu...-for-probe-basic-py3
when you get to the ini file be sure you understand what is in that link for the ini is NOT all that is needed, it must be integrated into your newly spit out axis ini file.
once you get it all copied over it should startup and run on your machine .
3 years 6 months ago #270270 by ihavenofish
Cool. thanks. i will be trying this after dinner.
3 years 5 months ago #271325 by K_R_Aviation
Just attempted to do a clean install and it seems like the new Repo links are broken!
Do we still have the google drive link?
links in question:
repository.qtpyvcp.com/repo/probe-basic-...5.3-3+81.dev_all.deb
repository.qtpyvcp.com/repo/qtpyvcp-dev/...4871882e.dev_all.deb
repository.qtpyvcp.com/repo/hiyapyco/pyt...pyco_0.5.1-1_all.deb
Thanks in advance
Kris
3 years 5 months ago #271428 by ihavenofish
go back to the first post. they changes the page and have new links
3 years 4 months ago #272793 by atomicmill
I ran into a problem trying to run Probe Basic Lathe. I installed Probe Basic following the instructions in the machine control install thread. I can run the probe basic mill sim, but the probe basic sim version throws the error:
  File "/usr/bin/probe_basic_lathe", line 5, in <module>     from probe_basic_lathe import main ModuleNotFoundError: No module named 'probe_basic_lathe'
Any tips on how to get the lathe GUI to work? Thanks!
The following user(s) said Thank You: TurBoss
Moderators: KCJ, Lcvette
Time to create page: 0.267 seconds
