User Install for Probe Basic Py3 (For Machine Control)
3 years 6 months ago #268553 by jordanm
Thanks for all this info. I was able to install Debian 12 and probe basic in a short amount of time because of all your work!
I did run into one issue when trying to install Linuxcnc where it was prompting me to insert the install media and it wouldn't complete the installation.
I was able to fix the issue by commenting out the top 2 lines of: /etc/apt/sources.list
Which were:
    deb cdrom:[Debian GNU/Linux bookworm-DI-alpha2 _Bookworm_ - Official Alpha amd64 DVD Binary-1
    with firmware 20230218-23:57]/ bookworm main non-free-firmware
With those commented out and the file saved, I retried the linuxcnc install command and everything worked past that point.
Thanks again for all the help!
3 years 6 months ago #268556 by rodw
Yes if this is what you are refferring to  docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
If you have problems with it looking on a CD, you may have used the wrong ISO. the netinstall I referr to in the link above does not have this problem.
The following user(s) said Thank You: buzzFab
3 years 6 months ago #268626 by jordanm
I guess I didn't see your google doc when I ran my install. I used the google doc from Lcvette, but what you have in your instructions makes sense as well.
Thanks again.
3 years 6 months ago #269173 by scotth
I have the sim running on 2.9.0 and python 3.11 on Mint 21.1
Sim looks like everything is working. No luck so far with a working hal or ini file for my 7i76 to test system. Anyone have these to look at, so I can edit my working axis hal and ini files.
3 years 6 months ago #269174 by Lcvette
There's a guide below this thread in the sticky section for converting a py3 config from working axis config.
The following user(s) said Thank You: scotth
3 years 6 months ago #269185 by scotth
I have it running now. I'll see what I have broken soon. Don't see how I would have ever got it running without your help on this. Thank you.
Moderators: KCJ, Lcvette
Time to create page: 0.173 seconds
