User Install for Probe Basic Py3 (For Machine Control)
3 years 7 months ago - 3 years 7 months ago #265962 by Lcvette
i just tried the alpha 2 iso and it installs the non free firmware by default now this is the unedited apt source list file from the base installation:
Last edit: 3 years 7 months ago by Lcvette.
3 years 7 months ago #265964 by Lcvette
Updated install files
3/6/23 1:26pm EST
3 years 7 months ago #265986 by nwallace
I can confirm that the new packages and instructions work on a fresh install of Debian 12. The only thing that I noticed is that the "sudo apt --fix-broken install" step after the python3_probe_basic package install will fail if you haven't already started LinuxCNC and copied an existing config to your home directory which creates the /home/user/linuxcnc/configs/ folder. You could also create those folders manually. Re-running the command after creating the folders works. I will edit my first post to not confuse new readers.
The following user(s) said Thank You: Lcvette
3 years 7 months ago #265998 by Lcvette
no need will add to the readme doc and yes i forgot about that
downside of working on an unclean system that had linuxcnc installed already and opened. I may be able to create the directory in the postinst script, I will try and see if it does it!
The following user(s) said Thank You: nwallace
3 years 7 months ago #266010 by nwallace
I have noticed that the carousel images are not loading. Anything I should check?
3 years 7 months ago #266012 by Lcvette
hmmm, let me check on that, i am just loading a clean installation of debian and going to test the debs to try and see if anything else popped up missing, will report back shortly.
Moderators: KCJ, Lcvette
