User Install for Probe Basic Py3 (For Machine Control)
3 years 7 months ago #267524 by HoBa
I did the installation yesterday according to the instructions. Since I use a Debian with the German language settings a minor error occurred. In my Linux the directory "home/user/Pictures" does not exist. Therefore I got an error at the end of the installation. This was no problem for me, I just created the directory and installed it again. Then everything worked as desired. I just wanted to mention it here.
Thanks for the detailed help here and also to all who contribute to this forum.
The following user(s) said Thank You: Lcvette
3 years 7 months ago #267540 by Lcvette
Thank you,  I think on the latest test branch I'm working on it will save to a created icons directory so the icons will be available from within the system icons directory when editing the launchers!
3 years 7 months ago - 3 years 7 months ago #267541 by KpAtch3s
Hey, reporting an issue with the install process with running the following command:
sudo dpkg -i python3-qtpyvcp_0.4-2_all.deb
(Reading database ... 179305 files and directories currently installed.) Preparing to unpack python3-qtpyvcp_0.4-2_all.deb ... Unpacking python3-qtpyvcp (0.4-2) over (0.4-2) ... dpkg: dependency problems prevent configuration of python3-qtpyvcp:  python3-qtpyvcp depends on python3-serial; however:   Package python3-serial is not installed. dpkg: error processing package python3-qtpyvcp (--install):  dependency problems - leaving unconfigured Errors were encountered while processing:  python3-qtpyvcp
--Update--
Just updating that I was able to get python3 serial installed. This was initially a clean install of debian 12 from the latest ISO. I also checked to see that python3 install was up to date. I was running 3.11.2. Followed the readme and after the above error I ran the following:
sudo apt --fix-broken install python3
It wouldn't install pyserial, thus I ran
sudo apt-get install python3 followed by sudo apt --fix-broken install. It then installed python serial.
I was then able to rerun the install on qtpyvcp and probe basic.
I'm basically brand new to linux, so the above my have been a bit of a weird work around, but it got the job done.
Last edit: 3 years 7 months ago by KpAtch3s. Reason: Clarity
3 years 7 months ago #267615 by Lcvette
updated the read me doc to add python3-serial!  thanks!
3 years 7 months ago #267618 by Lcvette
can you tell me what version of the .deb you were installing?  i just went back and looked and the latest does not use the pictures folder but the icons directory:
# Create the icons directory if it doesn't exist sudo -u ${SUDO_USER:-$USER} mkdir -p "${TARGET_HOME}.local/usr/share/icons" # Copy the probe_basic icons directory to the target directory sudo -u ${SUDO_USER:-$USER} cp -r /usr/share/icons/probe_basic_icon.png "${TARGET_HOME}.local/usr/share/icons/" sudo -u ${SUDO_USER:-$USER} cp -r /usr/share/icons/probe_basic_icon_lathe.png "${TARGET_HOME}.local/usr/share/icons/"
Thanks,
Chris
3 years 6 months ago - 3 years 6 months ago #268526 by buzzFab
@rodw
Is your linked guide still the best way of doing the whole ethercat / probe basic install? I see that now instead of using Lcvettes qtpyvcp-bookworm-installer on git hub they are recommending using python3-probe-basic_0.5.3_all .deb
Last edit: 3 years 6 months ago by buzzFab.
Moderators: KCJ, Lcvette
Time to create page: 0.518 seconds
