Probe_Basic ATC Tool List
- Lcvette
- Thank you received: 784
09 Dec 2023 15:25 #287674
by Lcvette
Replied by Lcvette on topic Probe_Basic ATC Tool List
or if you are on dev install and have a git manager such as gitkraken you can save your current installation to a new branch in your repository and checkout the probe basic main repository. you will also need to checkout the latest qtpyvcp as well.
- CNC_ANDI
- Thank you received: 31
09 Dec 2023 18:05 #287697
by CNC_ANDI
Replied by CNC_ANDI on topic Probe_Basic ATC Tool List
i dont have gitkraken or what else...
and i don´t know i have to do this.
i have only edited the probe_basic.ui nothing else...
can you tell me what i have to do for the dev update?
- Lcvette
09 Dec 2023 18:15 #287698
by Lcvette
how did you install it?
- CNC_ANDI
09 Dec 2023 20:38 #287715
by CNC_ANDI
i think like this one
www.qtpyvcp.com/install/bullseye.html
ok installed debian 12 on a other pc. probe_basic and my machine works but i cant load a nc programm.
probe_basic tells me can not probe with zero speed line -1 when i load a nc programm...
- Lcvette
09 Dec 2023 21:17 #287717
by Lcvette
did you reset the probing and tool setter parameters for your machine?
- CNC_ANDI
10 Dec 2023 10:35 - 10 Dec 2023 13:39 #287750
by CNC_ANDI
All the values was already at zero... i changed it to my values like the values before (from my other working pc).
But get always this failure when i load a program.
by the way have found a bug in the probe_basic.ui
the bug is in the atc page....
on the left side you have too buttons with atc fwd and atc rev
and on the right side you have it too...
but one side of this buttons works wrong
maybe you have to rename it or switch the ngc files
Last edit: 10 Dec 2023 13:39 by CNC_ANDI.
- Lcvette
10 Dec 2023 15:52 #287763
by Lcvette
Bug report: Thank you for that catch! you are correct, the buttons were inverted, I have corrected and the fix will go out in the next update I am working on! thank you for reporting that!
can you load the program on the atc sim? need to sort if its in the file, config or ui edits.
The following user(s) said Thank You: tommylight, CNC_ANDI
- CNC_ANDI
10 Dec 2023 19:09 - 10 Dec 2023 19:12 #287782
by CNC_ANDI
you are welcome!
ok got it now work on a normal debian 12 apt installation...
so please can you tell me how i can install editvcp to edit the probe_basic.ui?
any chance to do this?
i would do little changes....
axis display... i only need xyzb
rename some buttons or give it a other ngc file...
Last edit: 10 Dec 2023 19:12 by CNC_ANDI.
- Lcvette
10 Dec 2023 19:52 #287786
by Lcvette
that is set in the ini file based on your configuration for joints and axes, if you open the atc sim you will notice that only displays 3 axis, its all automated but requires a properly setup config file
- CNC_ANDI
10 Dec 2023 20:13 - 10 Dec 2023 20:15 #287790
by CNC_ANDI
i have 6 joints
XYYZBC
but C is actualy my toolchanger...
and probe basic gives me a XYZAB Display
but i would do other changes too.
XYYZBC
Last edit: 10 Dec 2023 20:15 by CNC_ANDI.
Moderators: KCJ, Lcvette
Time to create page: 0.111 seconds
