- Thank you received: 81
qtvcp issues
- auto-mation-assist
7 years 9 months ago - 7 years 9 months ago #123944
by auto-mation-assist
Replied by auto-mation-assist on topic qtvcp issues
I think that this may be a hal_glib problem but maybe not. Linuxcnc runs fine. Also recompiled linuxcnc just to make sure and it did that with no problems. Will look at the _hal.so file for a hint.
Last edit: 7 years 9 months ago by auto-mation-assist. Reason: Added some comments.
- Thank you received: 2181
7 years 9 months ago #123945
Replied by cmorley on topic qtvcp issues
looks like an error in _hal.so which will be c++ code.
I would try:
make clean;make
There has not been any significant changes in hal_glib for quite some time.
Chris M
I would try:
make clean;make
Chris M
7 years 9 months ago #123946
You are right but I did do a make clean before compiling again.
7 years 9 months ago #123947
It could be a system issue system issue because I get the same result from 3 different linuxcnc installations that have qtvcp.
7 years 9 months ago #123948
Is this work pushed to your repo - so i could test?
7 years 9 months ago #123949
I just recompiled on my system with no apparent problems running qtvcp or designer.
Chris M
Chris M
Time to create page: 0.162 seconds
