Preference File
- persei8
- Thank you received: 133
09 Feb 2020 10:08 #156883
by persei8
Replied by persei8 on topic Preference File
I must not have been caught up with the latest update because it works now. Sorry about the false alarm.
- Thank you received: 2181
09 Feb 2020 14:41 #156905
Replied by cmorley on topic Preference File
excellent! Thanks for checking.
Chris
Chris
- Bruedney
- Thank you received: 5
08 Apr 2020 00:57 #163154
by Bruedney
Replied by Bruedney on topic Preference File
Nooby question - what is the best method to ensure we have the latest build/release without losing any local changes to hal files?
I am also trying to find out why the Override Limits tick box is greyed out.
- bbsr_5a
- Thank you received: 106
08 Apr 2020 01:30 #163159
by bbsr_5a
Replied by bbsr_5a on topic Preference File
the newer kernels from 2.7+ will not have any changes
if you come from 2.6 or even lower you shout consider to regenerate the Machine and benefit from the new interpreter
and as you do this maybe go to a SUPERGUI like Dragon QTpyvcp
The following user(s) said Thank You: Bruedney
- Bruedney
08 Apr 2020 01:52 #163165
by Bruedney
I am running 2.8 - I was meaning when there are changes to QT Dragon
Bruce
Bruce
- Thank you received: 4154
08 Apr 2020 07:09 #163187
Replied by rodw on topic Preference File
Updating Linuxcnc should not change your configuration unless something you are using changes. It shouldn't. You are on 2.8 so a move to 2.9 would be seamless. The big change was from 2.7 to 2.8
08 Apr 2020 08:28 #163199
Override limts is greyed until you hit a limit switch.
Is this not the case for you?
Chris
Chris
- persei8
08 Apr 2020 10:43 #163205
by persei8
QTDragon is not an officially supported GUI. Officially, it's an example of what you can build with the QTVCP framework. However, if you want the latest files, you can directly download from Dropbox at www.dropbox.com/sh/348e4qenyyow2vl/AACRe...rSWlptHaO-sYDPa?dl=0
Jim
Jim
08 Apr 2020 11:29 #163211
Well I'll do bug fixing for the one included in linuxcnc, so that's about as official as it gets
Chris
Chris
- Bruedney
08 Apr 2020 13:48 #163224
by Bruedney
Thanks Chris
I have hit a software limit not a physical limit switch. This just me learning Linuxcnc after using Mach 3 for a while
Cheers
Bruce
Chris
Thanks Chris
Cheers
Bruce
Time to create page: 0.674 seconds
