Preference File
- Thank you received: 2181
11 Apr 2020 14:56 - 11 Apr 2020 14:59 #163650
Replied by cmorley on topic Preference File
You can use qtvcp's file dialog to just get the filename without loading the file by using a STATUS general message to call the dialog. In this way it manages size, placement extensions etc, but It wouldn't save the file name in the preference file or load the file into linuxcnc.
Chris
Chris
Last edit: 11 Apr 2020 14:59 by cmorley.
- persei8
- Thank you received: 133
27 Apr 2020 21:06 #165890
by persei8
Replied by persei8 on topic Preference File
Obviously I wasn't subscribed to this topic since I just now saw your reply. Anyway, I currently have 2 buttons for loading files, one for gcode and one for html. They instantiate a QDialog and all works well. However, I will try the method you suggest and report back.
Jim
Jim
- persei8
27 Apr 2020 21:34 #165892
by persei8
It does exactly what I am already doing but why does it report the contents of the dialog request 4 times? Can the filemanager widget be modified to not automatically load a selected file? This way, I could use it to just select a file and decide what to do with it based on the file extension.
[QTvcp.QTVCP.WIDGETS.DIALOG_WIDGET][DEBUG] Saving FileDialog-geometry data from widget screen_options to file. (dialog_widget.py:141)
OK - file dialog
{'RETURN': u'/home/jim/linuxcnc/nc_files/Dragon.ngc', 'TITLE': 'Load a GCODE File', 'EXTENSIONS': 'NGC Files (*.ngc);;PY Files (*.py)', 'NAME': 'LOAD', 'ID': '_load_gcode_'}
{'RETURN': u'/home/jim/linuxcnc/nc_files/Dragon.ngc', 'TITLE': 'Load a GCODE File', 'EXTENSIONS': 'NGC Files (*.ngc);;PY Files (*.py)', 'NAME': 'LOAD', 'ID': '_load_gcode_'}Please Log in or Create an account to join the conversation.
28 Apr 2020 00:32 - 28 Apr 2020 00:32 #165902
I don;t know why it reports four time - if you still have the relevent files I would love to see.
I just pushed an update to file_manager so you can class patch the load(self, fname):
function to call a function in the handler file instead.
There is an example how to do this in the qtvcp code snippets section of the docs.
Chris
Chris
Last edit: 28 Apr 2020 00:32 by cmorley.
- persei8
28 Apr 2020 10:16 #165985
by persei8
I haven't got the latest pushed update yet but I tried the class patching and it works. ( I didn't realize this is aka monkey patching )
Re: dialogs, every dialog that I call via
STAT.emit('dialog-request', mess)
or
ACTION.CALL_DIALOG(mess)
results in being reported 4 times in the console. You can probably only notice if linuxcnc is started from a terminal. This code is already in the example files.
or
28 Apr 2020 21:06 #166049
yes monkey patching.
From memory that can happen if you have multiple instances of the same dialogs loaded.
I'm not sure what you mean by 'already in the example files' which example files?
If you didn't update then your patching will probably break when you update I changed the function signature - easy enough to fix it.
chris
chris
- persei8
29 Apr 2020 12:19 #166110
by persei8
Sorry about the vagueness. To reproduce what I am seeing:
start linuxcnc in a terminal
select one of the configs under sim.qtvcp_screens.qtdragon
click on estop, power, home-all
click TOOL TOUCHOFF and wait for it to time out
There will be an error about timing out without making contact - expected
The contents of the dialog that was called will be displayed 4 times.
There's also something about Parameter file name is missing. - no idea what that is about.
Unrelated - there is an error about no attribute named proc but I have no interest in fixing that. I'm working on an updated version anyway.
30 Apr 2020 00:34 #166188
Thanks.
In axis_tool_button widget, In the function 'return_message', there is a debug print statement that printed _all_ return messages (and of course each tool button would print it too).
I'll remove it and hopefully that will be that.
Chris
Chris
- hottabich
- Thank you received: 96
01 May 2020 23:10 #166388
by hottabich
Replied by hottabich on topic Preference File
Hello Jim! Please tell me the mechanism of work of Probe Screen Widget.
Why the widget does not respond to probe-in. I see that everything is tied to a hal pin. I'm interested in how to connect to mesa 7i96. Thanks in advance!
- persei8
02 May 2020 08:47 - 02 May 2020 08:49 #166404
by persei8
I also use a 7i96 but I have the probe input run through a debounce component first. In qtdragon_postgui.hal file there is:
net probe-input debounce.0.3.in <= hm2_7i96.0.gpio.004.in
net debounce_p debounce.0.3.out => motion.probe-input
You could bypass the debounce and just enter:
net probe_input hm2_7i96.0.gpio.xxx.in => motion.probe-input
You can monitor the state of the hal pin in HALSHOW -> pins -> motion.probe-input. If it doesn't toggle with your physical probe input, then something is not connected right.
Also, the probe widget is inactive until the machine is ON and HOMED.
Jim
Jim
Last edit: 02 May 2020 08:49 by persei8.
Time to create page: 0.119 seconds
