Installing QtVCP
3 years 11 months ago #256362 by daiman444
Replied by daiman444 on topic Installing QtVCP
hi all. maybe I'm writing a question in the wrong place, but I would not want to breed new topics because of one question.
I compiled 2.9 installed without problems Qt from a script, all widgets are displayed, qtaxis, qtplasmac and so on are launched. I drew some sketches of the interface and I'm trying to run them like in the manual, but with my own configuration:
DISPLAY=qtvcp test.ui
I always did the same on 2.8 and it worked, but in 2.9 it gives an error:
[QTvcp.QTVCP.QT_PSTAT][CRITICAL]  No UI file found - Did you add the .ui name/path? (qt_pstat.py:135)
am i missing something?
3 years 11 months ago #256367 by cmorley
Replied by cmorley on topic Installing QtVCP
Hi. You didn't do anything wrong, it's just things changed from 2.8 and it seems the docs dod not get updated.
The ui and/or handler has to go in certain named folders. I'm awY from my computer so can't remember exactly but...
In a terminal type
qtvcp copy
And a dialog will show, that helps copy existing screens so you can modify them.i believe tester is an option
Or you can just look at the destination file path and figure out what qtvcp needs
The following user(s) said Thank You: daiman444
3 years 9 months ago #263167 by Pro_El
Replied by Pro_El on topic Installing QtVCP
Hello all
I have problem when i installed Designer 5.15.8
I have Debian Bookworm with LCNC 2.9.
I installed qtvcp from script for 2.9
But when i start qt from Terminal i get this:
cnc@am-082e5f06e065:~$ designer -qt=5
Qtvcp python plugin found: /home/cnc/.designer/plugins/python/qtvcp_plugin.py
[QtDesigner][INFO]  Logging to: /home/cnc/qtdesigner.log (logger.py:107)
tool_mmap_user(): file open fail: No such file or directory
tool_mmap_user(): no mmap file,continuing
mmap tool data not available, continuing emc/usr_intf/axis/extensions/emcmodule.cc
link (updating variable file): No such file or directory
And when i try to use some of the widget (like GCodeGraphics), the QT designer crush and got this on the terminal:
  File "/usr/lib/python3/dist-packages/OpenGL/latebind.py", line 43, in __call__
    return self._finalCall( *args, **named )
TypeError: 'NoneType' object is not callable
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3/dist-packages/qt5_graphics.py", line 760, in initializeGL
    self.realize()
  File "/usr/lib/python3/dist-packages/qt5_graphics.py", line 523, in realize
    self.font_base, width, linespace = glnav.use_pango_font(self._font, 0, 128)
  File "/usr/lib/python3/dist-packages/glnav.py", line 65, in use_pango_font
    glBitmap(0, 0, 0, 0, 0, h-d, ''.encode())
  File "/usr/lib/python3/dist-packages/OpenGL/latebind.py", line 47, in __call__
  File "/usr/lib/python3/dist-packages/OpenGL/wrapper.py", line 700, in wrapperCall
    raise err
  File "/usr/lib/python3/dist-packages/OpenGL/wrapper.py", line 693, in wrapperCall
    result = wrappedOperation( *cArguments )
  File "/usr/lib/python3/dist-packages/OpenGL/platform/baseplatform.py", line 415, in __call__
    return self( *args, **named )
  File "/usr/lib/python3/dist-packages/OpenGL/error.py", line 230, in glCheckError
    raise self._errorClass(
OpenGL.error.GLError: GLError(
    err = 1285,
    description = b'out of memory',
    baseOperation = glBitmap,
    pyArgs = (0, 0, 0, 0, 0, 23.0, b''),
    cArgs = (0, 0, 0, 0, 0, 23.0, b''),
    cArguments = (0, 0, 0, 0, 0, 23.0, b'')
Aborted
I cannot find on the forum some answers
Did i need some dependencies  or to change some paths... or maybe is still early for bookworm..
thanks
3 years 9 months ago #263177 by cmorley
I see there are all kinds of opengl problems reported on bookworm for AXIS and Gladevcp.
Qtvcp uses much of the same code.
The following user(s) said Thank You: Pro_El
3 years 9 months ago #263179 by Pro_El
Thanks Chris
i will wait couple of months till bookworm become stable..
it is very convenient because we can install LCNC from synaptic
3 years 1 month ago #280770 by nwallace
Replied by nwallace on topic Installing QtVCP
I followed the instructions to install qtvcp in the first post but the LinuxCNC widgets do not show in the designer. I am using Bookworm and the latest build of LinuxCNC 2.9. I have been searching and found nothing recent about this issue. My guess is that I just don't have the plugin for it. Can I get some guidance on where to look from here? It is difficult searching for more information on this when I don't know what questions to ask.
Time to create page: 0.075 seconds
