- Thank you received: 4153
Ok, Ill be giving bullseye a shot after I free up some SD cards, but its safe to assume that this issue was not fixed with new bullseye (I dont know if thats how computer things work or not)
Try the Debian Bookworm ISO from the Daily auto build here
raspi.debian.net/daily-images/
This does not give you a graphical environment.
I am slowly having another go at it. Currently trying to install the PREEMPT_RT. I left it go and went to work.
Here are my steps so far:Code:Login using the root account (which does not have a password yet). Type: root and hit enter Add a password to the root user account. Type: passwd and allocate a password you will never forget! Add a new user and allocate a password. I used pi: adduser pi Add your user to the sudo group. Type: usermod -aG sudo pi Type the following lines: apt update apt upgrade Type: apt-install linux-image-rt-arm64 linux-headers-rt-arm64 Reboot to boot into the PREEMPT_RT kernel log in with root and the password you set. Type: nano /boot/firmware/cmdline.txt and add this line: processor.max_cstate=1 isolcpus=2,3 save Install a graphical environment by typing tasksel Select a desktop environment. I selected xfce Tab to select ok, press enter and continue. Select a keyboard when prompted and continue. Don’t panic if the screen display appears corrupt, just wait until completed. Install linuxcnc. Type: apt install linuxcnc-uspace linuxcnc-uspace-dev Type startx to start the graphical environment Reboot into the graphical environment and log in with the username and password you created(I used pi)
Note this time I am using Synaptic to install the kernel and headers in step 6 to make sure we get the right ones
