Сustomization QTvcp
4 years 10 months ago #228972 by cmorley
Replied by cmorley on topic Сustomization QTvcp
I didn't know there was on - very nice!
4 years 9 months ago #231423 by hottabich
Replied by hottabich on topic Сustomization QTvcp
After updating linuxcnc 2.9, an error appeared when opening the interface as in the screenshot. Can this be fixed somehow without the help of a designer?
4 years 9 months ago #231442 by cmorley
you could use a text editor to edit the ui file.
Looks like the file simple_widgets needs an update too.
change in to print("false command")
4 years 9 months ago #231447 by hottabich
In the designer, if the python command option is selected for the button, then the false_python_cmd_string field should be empty. I fixed one button and everything works. Thank you so much for the advice.
4 years 9 months ago #231516 by cmorley
excellent. I will fix the action button print statement thanks.
The following user(s) said Thank You: tommylight, hottabich
4 years 8 months ago #234589 by hottabich
After updating linuxcnc 2.9.0 pre. does not work
Pause Spindle function. Error as in the screenshot.
Time to create page: 3.246 seconds
