Сustomization QTvcp
4 years 8 months ago #235049 by hottabich
Replied by hottabich on topic Сustomization QTvcp
Thank you so much, hal show is opening. But woodpecker doesn't work. The first screenshot is a regular version. Modified opens but  an error when the spindle is paused. When I prescribe Q hal I get an error like in the third screenshot. Please tell me how to fix. Previously, all this worked until 01/24/22.
4 years 8 months ago - 4 years 8 months ago #235093 by cmorley
Replied by cmorley on topic Сustomization QTvcp
Well I have to do a lot of guessing but:
First image error looks to be caused maybe when you press an action button?
looks like you are using the python command option. What was the command string?
Next image says you are trying to make a new HAL pin with the same name as an existing pin.
They seem to be probe related pin. Do you have two probe screens included or otherwise are creating pins with the same name?
Chris
Last edit: 4 years 8 months ago by cmorley.
4 years 8 months ago - 4 years 8 months ago #235107 by hottabich
Sorry I confused you. I ask questions one by one. Why doesn't the interface that comes with linuxcnc 2.9.0-pre0-5854 open. Error on the first screenshot and on the attached one now. Thanks!
Last edit: 4 years 8 months ago by hottabich.
4 years 8 months ago #235819 by cmorley
Ok I fixed the 'nonetype error' in master. Sorry it took so long.
The following user(s) said Thank You: tommylight, hottabich
4 years 6 months ago #240887 by hottabich
Thank you! The interface opens but the dialog box does not close. After several clicks, it gives an error. If possible, please fix it. Thank you!
4 years 6 months ago #240889 by cmorley
please post your handler_file
Time to create page: 7.017 seconds
