- Thank you received: 2181
Сustomization QTvcp
4 years 8 months ago #234617
Replied by cmorley on topic Сustomization QTvcp
Ok I pushed the fix to master.
Please let me know if that fixes it.
- hottabich
- Thank you received: 96
4 years 8 months ago #234631
by hottabich
Replied by hottabich on topic Сustomization QTvcp
There is no error but there is no spindle stop either. And also Hal Show does not open.Ok I pushed the fix to master.
4 years 8 months ago - 4 years 8 months ago #234666
Can you give any more info?
halshow loads in qtdragon on my machine.
spindle pause, if paused uses qtdragon code, requires HAL pins to be connected.
Last edit: 4 years 8 months ago by cmorley.
- hottabich
4 years 8 months ago #234673
by hottabich
I have it like this.
4 years 8 months ago #234675
The halshow problem is unrelated to qtvcp.
There was some work to halshow pushed that broke it in some situations.
I believe it was fixed, but maybe not in installed versions.
You use an installed version, not a compiled version of linuxcnc?
- hottabich
4 years 8 months ago - 4 years 8 months ago #234685
by hottabich
linuxcnc is installed from the official image. Then 2.8 was removed and using synaptic installed linuxcnc 2.9 which is updated from buidboot.
Last edit: 4 years 8 months ago by hottabich.
Time to create page: 0.165 seconds
