QRadioButtons in preferences file
11 Oct 2020 06:59 #185671 by rodw
Replied by rodw on topic QRadioButtons in preferences file
The real estate issue is hard to get around when trying to accommodate different screen sizes and aspect ratios...
I personally think the screen should be designed for 16:9 aspect ratio screens. Its really designed for touch screens and its hard to find a different aspect ratio (touch enabled) today at a reasonable price. This is the monitor I would use.
www.asus.com/au/Monitors/VT168H/
1368 x 768 (16:9) 15.6"
I bought one from Scorptech for $279
www.scorptec.com.au/product/monitors/17-22-inch/71962-vt168h
In the US its about USD $175
You can get industrial panels that size too.
My current touch screen is too big but thats partly the Gmocappy layout but I think the 15" will be perfect!
Oh and also the MDI keyboard is not following the theme, but I assumed it was a WIP. I could not see a space bar on it either.
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
11 Oct 2020 07:18 - 12 Oct 2020 01:40 #185673 by phillc54
Replied by phillc54 on topic QRadioButtons in preferences file
If you copy these into the config directory you will be able to see the arc voltage display plus a few LEDs.
Last edit: 12 Oct 2020 01:40 by phillc54. Reason: Add the correct files
11 Oct 2020 11:32 #185699 by rodw
It does not like your posgui.hal file.
Warning: Spoiler!
If I comment out the postgui in the ini file it opens....
  • phillc54
  • Platinum Member
  • Platinum Member
11 Oct 2020 11:42 #185700 by phillc54
Did you put all three files in the config directory?
11 Oct 2020 11:58 #185702 by rodw
Yeh, this error indicates, I also need a sim in my system and I don't think I would have that..
/home/rod/linuxcnc-plasmac/share/qtvcp/panels/qtplasmac_sim/qtplasmac_sim.ui
11 Oct 2020 18:17 #185736 by cmorley
Replied by cmorley on topic QRadioButtons in preferences file
QT screens go in your config folder or:
/home/rod/linuxcnc-plasmac/share/qtvcp/screens/THE_SCREEN_NAME/
  • phillc54
  • Platinum Member
  • Platinum Member
11 Oct 2020 22:46 #185774 by phillc54
That sim panel is load from the postgui:
loadusr -Wn qtplasmac_sim qtvcp qtplasmac_sim.ui
So it should have found it in your config folder.
This is what I get:
Warning: Spoiler!
11 Oct 2020 23:08 #185777 by rodw
I downloaded both zip files and reviewed the contents. You have not sent me
qtplasmac_sim.ui
Can you send it through? I won't be able to look again until tonight.
  • phillc54
  • Platinum Member
  • Platinum Member
12 Oct 2020 01:38 #185780 by phillc54
qtplasmac_sim.ui
Oops :blush: :blush:
  • phillc54
  • Platinum Member
  • Platinum Member
12 Oct 2020 05:07 #185794 by phillc54
Well I built a VirtualBox VM and it also shows the colors correctly, looks like more tail chasing...
Time to create page: 0.242 seconds
