QtDragon, Linuxcnc 2.9pre, and Debian 12 (bookworm)
  • Roguish
  • Roguish's Avatar Topic Author
  • Elite Member
  • Elite Member
28 Aug 2022 15:25 #250649 by Roguish
I changed it with grub_customizer....
lots left over from earlier distros
28 Aug 2022 15:27 #250650 by cmorley
apparently sometimes the 5.x isn't as good.
If 4.x works...
  • Roguish
  • Elite Member
  • Elite Member
28 Aug 2022 15:48 - 28 Aug 2022 15:49 #250651 by Roguish
Chris,
I edited those 3 files that you changed.
and even changed the extension on the matching .pyc files.
still no luck.
terminal output is attached.....
could this be because I have a customized qtdragon ???
Last edit: 28 Aug 2022 15:49 by Roguish.
28 Aug 2022 16:07 #250653 by cmorley
change these lines:
elif self._shape == 1:
x = int(self.width() - self._diameter - self._right_edge_offset)
y = int(0 + self._top_edge_offset)
The following user(s) said Thank You: Roguish
28 Aug 2022 16:07 #250654 by cmorley
keep the original indenting though
28 Aug 2022 16:10 #250655 by cmorley
in simple_widget.py I should say
  • Roguish
  • Elite Member
  • Elite Member
28 Aug 2022 16:20 #250657 by Roguish
Chris.
got it.
WORKS.
THANKS.
i will post again if there are any more oops.
please put that in the src files......
pere says minimum 12 hours for changes to show in the repository files.... we'll see.
28 Aug 2022 16:25 #250658 by cmorley
Excellent!
Thanks for doing some leg work and prodding.
12 hours wow. I hope that can be improved in the future.
I'll push the remaining fix soon.
Chris
  • Roguish
  • Elite Member
  • Elite Member
03 Sep 2022 12:21 #251112 by Roguish
Chris.
well found a few more arg type problems.  while starting up Dragon and clicking through the tabs.
I searched a bit and modified 2 files:   simple_widgets.py   and hole_circle.py
the files are attached here.
the edits are not pretty, but no errors, yet.
simple_widgets errors were in the Dragon Versa Probe tab.  see line 617
hole_circle errors were in the Dragon Utilities tab.    see lines 40 thru 100
could you possibly clean up the files?   and push 'em??
I have no idea if that's all the errors.  I'm just starting to use my system.
thanks.
I'll keep watching for errors....
03 Sep 2022 12:56 #251118 by cmorley
There is too much difference in simple_widgets to use it. either you took too much out or your base version was too old.
A diff of your changes would be much easier for me.
Time to create page: 0.157 seconds
