Error message when closing qtplasmac
3 years 9 months ago - 3 years 9 months ago #262845 by snowgoer540
Replied by snowgoer540 on topic Error message when closing qtplasmac
Actually, it looks like maybe its from a debug print left in.
Let me see if I can track it down...
EDIT:  It is from this commit:   github.com/LinuxCNC/linuxcnc/commit/5d05...80a914ca8d6881a8e4a1
Prior to that commit I get no "error" on shutdown in the terminal, after that, I get the following:
<__main__.QTVCP object at 0x7fa9064912e8> Shutting down and cleaning up LinuxCNC... task: 523 cycles, min=0.000001, max=0.020910, avg=0.010125, 0 latency excursions (> 10x expected cycle time of 0.010000s) Note: Using POSIX non-realtime LinuxCNC terminated with an error.  You can find more information in the log:     /home/plasma/linuxcnc_debug.txt and     /home/plasma/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal
Running Buster 10 (MX Linux 19.4)
Last edit: 3 years 9 months ago by snowgoer540.
3 years 9 months ago #262846 by snowgoer540
Moved the thread to qtvcp so Chris would see it :)
The following user(s) said Thank You: paulsao
3 years 9 months ago #262853 by cmorley
Replied by cmorley on topic Error message when closing qtplasmac
I'm stumped on how to fix this.
There isn't really an error (well in this case I'm assuming it's the usual segfault).
It is known problem with pyqt, that seems to be in this case sensitive to exiting HAL (which is the part I added back)
I'm open to ideas from coding experts.
Chris
3 years 9 months ago #262889 by paulsao
Replied by paulsao on topic Error message when closing qtplasmac
Chris
Thanks for the help, hopefully I can fix that :)
3 years 9 months ago #262911 by snowgoer540
Chris
I'm a bit confused since normally the segfault "errors" show up on versions greater than Buster.
Both paulsao and I are running Buster, which seemed to be previously immune from this (I thought anyways).
Otherwise, I am out of ideas, it's probably way above my pay grade.
3 years 9 months ago #263032 by snowgoer540
Maybe this wasn't above my pay grade after all...
Made some headway, Chris pushed this fix:  github.com/LinuxCNC/linuxcnc/commit/4683...968022550a6395c38ff4
Should be improved, but report back if it isnt!
Time to create page: 0.164 seconds
