- Thank you received: 4153
Error message when closing qtplasmac
3 years 9 months ago #262831
Replied by rodw on topic Error message when closing qtplasmac
On your screen dump, there is a icon that says Debian 11 which is BUllseye and your kernel is 4.19 which is buster.
What version of debian are you running?
Can you share the output from
lsb_release -a
The following user(s) said Thank You: paulsao
- paulsao
- Thank you received: 22
3 years 9 months ago #262838
by paulsao
Replied by paulsao on topic Error message when closing qtplasmac
lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
Release: 10
Codename: buster
- paulsao
3 years 9 months ago #262839
by paulsao
it appears to be something with qtvcp.
Can you try changing in the [DISPLAY] section the DISPLAY = qtvcp line to DISPLAY = qtvcp -i, running it again and getting the new error report?
- phillc54
- Thank you received: 2100
3 years 9 months ago #262841
by phillc54
Replied by phillc54 on topic Error message when closing qtplasmac
Can you successfully run the standard QtPlasmaC sim?
- paulsao
3 years 9 months ago #262842
by paulsao
Qtplasmac works fine, the only thing that happens is that when closing I get that error message, I didn't have it until yesterday morning
- snowgoer540
- Thank you received: 907
3 years 9 months ago #262843
by snowgoer540
I see what you are talking about in my terminal as well with both package and run in place.
I do know that Chris was working on some stuff to prevent segfaults. I wonder if this is related.
I think I will move this thread over to QTVCP so he sees is, unless someone objects?
Replied by snowgoer540 on topic Error message when closing qtplasmac
Qtplasmac works fine, the only thing that happens is that when closing I get that error message, I didn't have it until yesterday morning.
<__main__.QTVCP object at 0x7fdd11f992b0>
Time to create page: 0.229 seconds
