Error message when closing qtplasmac
3 years 9 months ago #263070 by rodw
Replied by rodw on topic Error message when closing qtplasmac
I can't see anything has changed in that commit. All I could see was an additional logging call.
what does LOG.debug do?
3 years 9 months ago - 3 years 9 months ago #263088 by snowgoer540
Replied by snowgoer540 on topic Error message when closing qtplasmac
It's at the very bottom. Changed sys.exit(_qtvcp) to sys.exit(_app)
github.com/LinuxCNC/linuxcnc/blob/8890c4.../qtvcp/qtvcp.py#L509
Line 427: LOG.debug('Exiting HAL')
It passes the string following it ('Exiting HAL') to the logger at the level indicated (debug in this case, the levels are: debug, info, warning, error, critical, verbose).
Worth noting - the default level is "warning", so you will only see log messages at warning level and above in the terminal. If you want to see lower than that, you can use a one of the options that is set in the display section of the ini file after "qtvcp".
DISPLAY = qtvcp -d qtplasmac
Would set logging to the debug level for qtplasmac.
Last edit: 3 years 9 months ago by snowgoer540.
3 years 9 months ago #263134 by rodw
Thanks for clayifying. I missed that!
I just  pulled the 2.9 branch and it does seem to work running a Woodpecker sim which is QTVCP based.
I always wondered why it affected QTVCP and not QTPYVCP yet we were told it was out of our control so live with it.
3 years 9 months ago #263135 by rodw
And the qtplasmac sim exits cleanly too!
3 years 9 months ago #263138 by snowgoer540
Chris did the heavy lifting, I just found that last little bit.
Thanks for the extra data point. I tried qtplasmac, qtaxis, qtdragon_hd and a few others, but not woodpecker.
Fingers crossed it stays fixed...
The following user(s) said Thank You: paulsao
3 years 8 months ago #263724 by paulsao
Replied by paulsao on topic Error message when closing qtplasmac
Is there a way to fix it, maybe if I install other versions?
Time to create page: 0.379 seconds
