Rods "Spaceship" Scratch built Plasma Cutter build
7 years 4 months ago #137691 by phillc54
Don't forget about that dude named Murphy... ;)
7 years 4 months ago #137712 by pl7i92
is the laserpointer on both sides of axis
i put mine in one axis here it is X to the torch so i got only one ofsett
and your crosshair is then the point to start actuly it is the negative to the Torch
G10 L20 P1 x0 y-35 (in my case )
then as i got this done by a Button press
i go
M112 reload the Graphics axis−remote −−reload
G54 G0 X0 Y0
to be on the start point XY
7 years 4 months ago #137717 by rodw
pl7i92 wrote: is the laserpointer on both sides of axis
i go
G54 G0 X0 Y0
I deliberately offset it on both axes so it could reach 0,0 plus it was easier to mount that way!
Gmoccappy supports macro buttons so I've put it there for now. I think I'll try and move it to one of the buttons Phill has added to the Plasmac front screen. He has one that opens halshow but it can also be opened from the settings page So I was hoping to put it there.
7 years 4 months ago #137719 by rodw
Phill, thanks what about an example to call a g code subroutine file? I seem to remember the first version of plasmac I installed had one but you changed it!
7 years 4 months ago - 7 years 4 months ago #137720 by phillc54
Have you tried
o<my_sub_routine> call
I'm kinda thinking it should work...
Cheers, Phill.
EDIT: Yes it does work, I added it to the docs.
Last edit: 7 years 4 months ago by phillc54.
Time to create page: 0.375 seconds
