- Thank you received: 7491
In the mean time of doing other things, i am also building a small frame for a plasma cutter with the cheapest parts i can find here, with round linear rails all over, belts and stuff, but trying to make it look better as a whole. Size 55X95CM.
tommylight wrote: John, you are responsible for confirming that Linuxcnc can do anything you think off, and do that in several ways, usually. My complaints are regarding new users and the ensuing workload for Phill and the others here in the forum. It would have been much better to have a simpler version, ready for use by them by now, and continue working on the actual version. That would have left users the option to choose, and not be thrown on the deep end to start with.
Just noticed, sorry for hijacking your thread, Rod.
Personally i can use anything and modify it to my liking, but i can not use Plasmac on clients machines anymore since people here where i live do not wait for a week or two to have their machine fixed, at encountering any issue, i have to leave whatever i am doing and go check and fix whatever is needed.
Back on topic......hmmm.... at last,
Regarding holes, usually i avoid anything under 30mm for a good cut, and making small holes and later drilling them to size is not an option as it tends to mess up drill bits on short notice. This is for parts cut on a water table, have not tried to do that with cuts on air, maybe that will work as the material would cool down slower so the inevitable hardening of the cut would have to be less of an issue.
Also will have to make 2 holders for the new torch heads i got several months back, but had not time to put them to use. Unfortunately derlin or HDPE is very expensive here and finding big parts for those holders is hard and way more expensive. Making an attempt tomorrow, wondering how much of a shock the price will be.
Regards,
Tom
P.S.
I am going to attempt to build a small one as well so looking forward to see yours.To gain Ideas .
tommylight wrote: Rod, thank you very much.
It is also frustrating that so many web sites do not list my country at all, so I order through friends in other countries.
Also I can find HDPE in only 20x30x0.8 cm at some kitchen stuff stores here, used for chopping food or whatever .
