Rods "Spaceship" Scratch built Plasma Cutter build
7 years 4 months ago #135964 by stevec
@ pl7i92
At 1 minute 25 secs of the video around 9 o'clock position on the machine - have you got critters living in the water in the plasma tray? :)
7 years 4 months ago - 7 years 4 months ago #135968 by Grotius
Tommy,
It is also frustrating that so many web sites do not list my country at all
No problem at all. You are OEM of TD and HP already without noticing. Did you ask me something?
My connection's in Servie and Russia are good. But Tommy is my friend. His country has the perfect tax rate.
Bosnie is perfect to start up a company !!! Australia is also good to start up a company for plasma cutter's !!
Do we have a point over here?
Rodw has a existing company in car parts so far i know. So set up a plasma company with a linux based software platform can
be a good stratagy for Rod. Then Rod can finally buy a mclaren from England, or a Rolls Roy's let's say this one :
Linux is powerfull. It attrack's money with the flow. Don't let Swiftcut rule your life. It's a company pure based on investor's without any soft or hardware knowlegde. That will kill them on therm for sure. Keep in mind my words. Purelogic is a russian company with the same perspective stratagie. A more intelligent company related to Swiftcut, but way to expensive.
When you have the car. Put your usb device in it and ride along. Good music at the course.
Last edit: 7 years 4 months ago by Grotius.
7 years 4 months ago #135990 by tommylight
Hmmmm.........sitting in a 300000 euro car and listening to "the thril is gone" ?!?!?!?
No way! The thril would have just started, big time! :)
Life has been cruel to me lately, the last fast car I drove had only 508 HP! That was several years ago, now I drive a diesel ! At least I get less speeding tickets! A lot less! Damn, I must have payed over 300 speeding tickets in my life time! No point system here and the min and max values where between 25 and 85 euros, last year all that changed, minimum is 200 and 1 point lost !
So in a way I was very lucky! :)
Rod, sorry, off topic again. We owe you a lot of beers !
7 years 4 months ago - 7 years 4 months ago #137114 by rodw
tommylight wrote: the last fast car I drove had only 508 HP! That was several years ago, now I drive a diesel ! At least I get less speeding tickets! A lot less!
Tommy, I think you need to upgrade to a diesel 4WD and then you can spend all your spare money with me making it go even slower!
Anyway, in amongst a bit of business related Python programming, I managed to get this half installed on my table today.
I thought this laser pointer was a pretty good buy for $40. I had a tiny little one here that I had thought of fitting up but it was only a single dot and this one already had a mounting ring so it was real easy to fit using plasma cut plate screwed to the torch holder. I still have to wire this in to power. Unfortunately, the cables going up onto my gantry are all used, so I'm going to add a manual switch to turn this on. This is a 5 volt device and I purchased a small 24 volt to 5 v power supply which should fit into the existing metal box on the gantry.
I know its mounted fairly low but I found it had to be mounted well away from the torch if it was any higher so I hope it works out OK over time..
It is pretty square, just the material I put down isn't! I found just tightening the 4 grubscrews that hold the laser tube twisted it off square.
So if anybody has any ideas on how to handle the offsets to use this, I would appreciate some pointers. I know what I have to do to calculate the offset and square it. but its the software stuff I'd like to know a bit more about.
Last edit: 7 years 4 months ago by rodw.
7 years 4 months ago #137126 by islander261
Rod
Several years ago on PS there was a guy that installed a switch on a pneumatic cylinder for probing. As I recall he had a couple of Gcode subroutines that he used for probing.
I would be inclined to just write a small MDI macro to do it since you are not probing. Move material or crosshairs to desired location then make an offset move to put the torch there.
I actually built mine with two laser line generators mounted 90 degree apart that cross under the torch. I use clear packing tape for a window to protect the lasers, it lasts about a month and then I put on a new piece.
7 years 4 months ago #137147 by tommylight
Rod,
I had an Audi Quattro, sold it some 5 years ago ( more like donated it to a friend ), but I made it go faster by changing and uploading some software! These new cars with to much electronics took all the fun out of making them go faster! In my young days we had to yank the engine out, disassemble it totally, change the head with one that had bigger valves, lower the head and block to the point that cylinders were nearly bumping on said valves, make 4>2>1 exhaust, but bigger nozzles on the carburetors etc etc etc. That was fun!
Also got one of those lasers with a cross but smaller one for 15 euro a while back, still in it's package waiting! :)
BTW, did you get the message? I got no confirmation for it!
Time to create page: 0.145 seconds
