Rods "Spaceship" Scratch built Plasma Cutter build
6 years 8 months ago #157039 by tommylight
Here we use something called "ferro beton" that is added to concrete surface and it to be very hard, usually green in color. It is the same thing gas stations use as it is very easy to maintain and clean due to very smooth surface.
I was quoted nearly 4000 Euro for 80 sq/m of my shop, so i had to skip that for now.
If and when i move, i will have to do that, it just looks neat.
The following user(s) said Thank You: rodw, CNCFred
6 years 6 months ago - 6 years 6 months ago #163470 by rodw
Its a while since I posted here.I guess that is becasue my plasma table is essentially complete. But it could do with a Z axis cover.
I finally worked out how to nest parts in waste (from inside cuts) and also worked out how to get sheetcam to sever a sheet after a nest is cut on my 1200 x 1200mm table. So I managed to get Sheetcam to cut 2 x 900 mm sections and 1 x 600 mm section from a 2400 mm sheet. I had a couple of goes at this (Yes I cut 2 sheets). If I did it again, I would cut the 600mm section first instead of last becasue I got a lot of warpage which caused probing errors with Plasmac because the probe was triggering too early. I'd love to see PLasmac compensate for a probe error that occurs before the Z axis gets to probe height.
Anyway, here is a short video
And for the diehard fanatics here is an extended one.
Last edit: 6 years 6 months ago by rodw.
The following user(s) said Thank You: phillc54, CNCFred
6 years 6 months ago - 6 years 6 months ago #163471 by rodw
So here is what we had left...
The following user(s) said Thank You: tommylight, CNCFred
6 years 6 months ago #163496 by tommylight
Efficient use of material ! Nice.
The following user(s) said Thank You: CNCFred
6 years 6 months ago #163579 by CNCFred
As hobbyist I am very impressed!
  • thefabricator03
  • Visitor
  • Visitor
6 years 6 months ago #163590 by thefabricator03
Replied by thefabricator03 on topic Rods "Spaceship" Scratch built Plasma Cutter build
Rod, Is that video sped up? Or is that real time?
That machine is sure moving!
Time to create page: 0.305 seconds
