Rods "Spaceship" Scratch built Plasma Cutter build
6 years 11 months ago #151650 by machinedude
well cold weather or not you must be doing something right. to have the chance to experience an event like that and travel for work related stuff i would consider a blessing. what ever your doing keep at it it seems to be working well for you :)
i would probably pass on the spear in the nose deal though and be happy at home :)
i hope you enjoy the trip and gain some good stories to tell later :)
6 years 10 months ago - 6 years 10 months ago #152427 by rodw
Well today was the first time I cut a full 2400 x 1200 sheet since I added a water table.
First observation is that Tommy was right . We made quite a splash around the machine because we don't have sides much higher than the slats. But becasue its only a half sheet table, we need to be able to index the sheet so this is kinda needed. I might look at working out how to add higher sides and keep the ends low for indexing sheets.
Second observation is how much nicer cut quality is. This really surprised me. What little dross that was on the sheet just knocked off to reveal a perfect finish with little effort and no grinding. Much better than cutting over air. Very happy about that.
Third observation is that I really need to add a parking position in Sheetcam to move to the centre of the table after cutting until the air flow finishes.
So a question. What do people use to knock dross off the sheet? Has anyone made a tool? If so what did you come up with?
PS. Plasmac's sheet sever features works really well!
Last edit: 6 years 10 months ago by rodw.
6 years 10 months ago #152430 by tommylight
I just throw the parts on the concrete, that usually gets rid of 95 % of the dross.
6 years 10 months ago #152475 by rodw
tommylight wrote: I just throw the parts on the concrete, that usually gets rid of 95 % of the dross.
We have so little dross now with a water table, we were even wondering if the sandblasting as the part gets powder coated would be enough. I think it probably would be...
Today we stopped spotting holes and just cut them and even 6mm holes came out perfect for M5 clearance holes. The 9mm holes for nutserts are also perfect!
The following user(s) said Thank You: tommylight, CNCFred
  • thefabricator03
  • New Member
  • New Member
6 years 8 months ago #157026 by thefabricator03
Replied by thefabricator03 on topic Rods "Spaceship" Scratch built Plasma Cutter build
Lol, Tom must be getting into the concrete floor repair industry.
I laid the concrete in my shed at home myself and took great care in preparing to surface to perfection. I just cannot fathom throwing heavy object at it on purpose lol. Although the 60 year old floor at work is fair game.
Off topic but the Yanks have a lot of products for their "garage" floors. Tiles, epoxy finishes, they really know how to create man caves!
6 years 8 months ago #157028 by rodw
That was my mistake. I put my little shed on an existing exterior slab that had a lot of slope on it. Plus its exposed aggregate so if you drop something, you can never find it again. Then not long later I poured a slab behind it to put a 5000 litre rain water tank on in a drought when the council was paying for half of it. The slab is the same width as the shed. I wish I had poured a big slab for the tank and the shed.
There is a concrete flooring product called Lanco that you pour on a floor like custard and it self levels. I have thought of pouring it into the shed to level the floor up 25mm but I was put off because I had so much gear in there and would have done it in sections. Now most of the stuff has been moved to my work building so its basically just a BBQ storage shed now so I could probably do it pretty easilly.
The following user(s) said Thank You: tommylight, thefabricator03
Time to create page: 0.534 seconds
