- Thank you received: 83
Rods "Spaceship" Scratch built Plasma Cutter build
- billykid
4 years 6 months ago #239728
by billykid
Replied by billykid on topic Rods "Spaceship" Scratch built Plasma Cutter build
Very nice Rod!
I'm almost ashamed to show you mine at least the panel is milled and written with my cnc.
- Thank you received: 4153
4 years 6 months ago #239731
Replied by rodw on topic Rods "Spaceship" Scratch built Plasma Cutter build
So many ways. I did think of making a plasmacut enclosure and folding it up. I have done one before which looked amazing once it was powdercoated. But really for $200, the enclosure seemed to be the easier way. The needed to be a lot of standoffs for DIN rails etc to be welded on.Very nice Rod!
- my1987toyota
- Thank you received: 449
4 years 6 months ago #239732
by my1987toyota
Replied by my1987toyota on topic Rods "Spaceship" Scratch built Plasma Cutter build
Building an actual enclosure box seems to be one of those things you do once, then understand why they are the price they are.
At least that's how it was with me. LOL
- BruceCharlesDesigns
4 years 6 months ago #240481
by BruceCharlesDesigns
Replied by BruceCharlesDesigns on topic Rods "Spaceship" Scratch built Plasma Cutter build
That looks awesome! Your mention of running the stepper drivers on AC reminded me of some experimenting I did on an old Tormach 1100. Bypassed the 48v DC altogether and put in some DM2282T drivers connected directly to the 220v in. Made a much cleaner system, and I could run the steppers with about 4 times the acceleration and more than double the ultimate speed with those drives at the higher voltages.
Made me wonder why I wouldn't go that route on any homebuilt machine. The DM2282T were not cheap, but compared to drivers and a good DC transformer setup it wasn't that big a difference. And definitely would simplify the enclosure!
I almost never see these drivers used anywhere.
Regardless, I have learned a lot from your posts and your youtube vid on your build. Thanks for sharing all of it!
4 years 6 months ago #240527
The other thing I've been playing with are ethercat drives. This enclosure is on my mill conversion. 400 x 400mm was all they had in stock and its just not big enough to use conduit.
It has very simliar bones to the plasma control box. Same safety circuit, same power supplies same fan, just not enough room to be tidy.
Hmm, still a lot cheaper than what the drives and power supply in that box are.Bypassed the 48v DC altogether and put in some DM2282T drivers connected directly to the 220v in. Made a much cleaner system, and I could run the steppers with about 4 times the acceleration and more than double the ultimate speed with those drives at the higher voltages.
The following user(s) said Thank You: tommylight, RNJFAB, arcsynapse89
- RNJFAB
- Thank you received: 59
4 years 6 months ago #240788
by RNJFAB
Replied by RNJFAB on topic Rods "Spaceship" Scratch built Plasma Cutter build
I'll have to head up soon Rod and check out all the amazing work.
Time to create page: 0.679 seconds
