Mazak Micro Slant 15 Retrofit
9 years 5 months ago #93247 by tommylight
Had a bit of a misshap today so i am currently out of order. Grabed a freshly welded piece of 30mm round bar and ended up with several grade 1 and 2 burns on the right hand. Gona take quite some time to be able to use the hand properly, so wont be doing much in the near future. Will be checking in here more offten, so do something so i can keep myself occupied!
With utmost respekt,
Tom
9 years 5 months ago #93250 by rodw
Replied by rodw on topic Mazak Micro Slant 15 Retrofit
Tommy, take care while you mend. In the meantime, we'll probably get tired of your activity on the forum ..... Just kidding.... . :woohoo: :woohoo: :woohoo:
I for one always value your input
9 years 5 months ago #93280 by tommylight
MAZAK in da hauseeeeee!
Finally got it in the workshop, the forklift (5 ton capacity but very old ) had problems lifting it from the ground so we pushed it in using wooden pallets under it to prevent it from scraping on the floor. What a relief after 8 days of siting outside in the rain, properly covered.
Rendered 1/3 of the place unusable, has to be 80cm away from walls.
Here is a picture of it inside,
And here is how the rest of the shop looks from making place for this "micro" thing !
More fun.......ehm.... i think so ! :)
9 years 5 months ago #93546 by RotarySMP
Hope you burns are healing well.
That Mazak looks like it will be quite a project if you plan to convert it.
Mark
9 years 5 months ago #93636 by tommylight
Hand healed pretty damn quicly as i can do almost everything with it by now, still has a fuzzy feeling in some parts of the palm, but all is good, very.
Thank you all.
Mazak and most of the projects are still on a status quo, have to get something else done.
Will update whenever i get back.
9 years 3 months ago #95743 by johnmc1
Good Day ,
There is a Mazak micro slant 15 manual on ebay, but it has a Fanuc 6t controller.
Cheers john
Time to create page: 0.353 seconds
