Robertspark's CNC Setup
4 years 8 months ago - 4 years 8 months ago #234101 by robertspark
I thought I could set myself up a thread which I could use as a central repository for my current setup(s) for my LinuxCNC setup.
This also allows me to setup my LinuxCNC setup quickly if I do a fresh start in a short space of time.  I've posted some of my settings on a few threads and I do a search for those when I set up from a clean slate to start again.
These settings may not work for you!   Then again you may learn something like I have following all the countless installs of LinuxCNC via iso / buildbot / RIP installs on Debian Buster, Bullseye and MX21 etc.
My current setup is: Debian Buster LinuxCNC 2.8.2 installed via iso on usb stick.
I have:
* list ~5x5 home built plasma running on 50x50 rails, nema23 4.2A all round with Mod1 R&P with a 3:1 gear driven reducer on X, Y & Y1 axis, Z is via a 1204 ball screw, complete with attached air scribe, laser crosshair and magnetic breakaway that allows for install of a laser diode (not used it yet), scanning camera (not used it yet), and sharpie holder.  Also a 4th axis rotary tube (CHS/SHS) with a 100mm 4 jaw self centring chuck.
* list Denford Orac Lathe, running with 750W servo motor spindle (2:1 reduction drive) and spindle shaft encoder (1000ppr) using 40 position mutifix quick change tool post.  X and Z are 0.001mm/step.
* list Emco / Maximat FB2 3 axis mill with stepper converted rotary table, converted to cnc using nema 34 stepper motors and HTD belt reduction for 0.001mm/step per X,Y and Z axis.
* list 3 axis router, openbuilds Cbeam-XL, with makita rt0700c router, and SuperPID speed controller, with laser diode, and drag-knife attachment
Non Linuxcnc:
* list Creality CR-10S 3D printer
* list Atomstack A10/S10/X7 with M50 laser and Ortur rotary axis
LinuxCNC uses a Mesa 7i76E + THCAD5 for the Plasma and a Mesa 7i92H + 7i76 mill router and lathe (hence 2 x static ports setup in the interfaces file)
I have 2 x Mesa ethernet devices, each on its own ethernet port / network adapter hence they are each setup with their own static IP address.
I share the 2 x Mesa ethernet devices between all of the machines, basically the plasma, mill and router use the 7i76E which drives 5x stepper drives, and the 7i92H+7i76 is used for the lathe driving 2 stepper drives, and a servo for the spindle.  The stepper drives have plugs & leads so I swap between machines from a central control station its a hobby setup and I don't use more than one machine at any one time.
if required, download linuxcnc.iso:
once downloaded copy across to usb disk
find which drive is the usb stick using:
lsblk
navigate to the downloaded iso and run:
sudo dd if=linuxcnc-2.8.2-buster.iso of=/dev/sdc bs=1024k status=progress
Once Debian Buster and LinuxCNC is installed via the iso, run:
sudo apt update
sudo apt upgrade -y
sudo apt install -y geany grub-customizer git ethtool python3-opengl gnome-icon-theme curl dpkg-dev xfce4-power-manager
sudo Thunar
navigate to: /etc/lightdm/ and open lightdm.conf
alternative:
sudo geany /etc/lightdm/lightdm.conf
scroll down to line ~ 126 and remove the # + add your user name from:
#autologin-user=
#autologin-user-timeout=0
I have intel network cards, hence the following helps to sort latency issues.  I found that ethtool works and the other method did not work for me.  plus I added a 3 sec delay to the process or it did not have effect.  It works for me, your mileage may vary....
navigate to: /etc/network/ and open interfaces
alternative:
sudo geany /etc/network/interfaces
edit to YOUR needs, below is mine, 99.9% certain this WILL NOT work for you, as your ethernet adapters may have different names and my mesa cards are on different ports + they have custom IP addresses set via the mesa firmware tool.
run the following to list your network adapters names:
ip link show
# This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5). source /etc/network/interfaces.d/* # The loopback network interface auto lo iface lo inet loopback auto enp2s0 iface enp2s0 inet static address 10.10.10.1/24 up sleep 3 post-up ethtool -C enp2s0 rx-usecs 0 auto enp3s0 iface enp3s0 inet static address 172.16.0.1/24 up sleep 3 post-up ethtool -C enp3s0 rx-usecs 0
Last edit: 4 years 8 months ago by robertspark.
4 years 8 months ago - 4 years 8 months ago #234104 by robertspark
Replied by robertspark on topic Robertspark's CNC Setup
open up grub customizer and shorten the wait time to 1 second, and add in the following
quiet splash isolcpus=1,3
install the following:
sudo apt install -y inkscape gimp librecad freecad
download sheetcam:
www.sheetcam.com/downloads
download scanything:
www.sheetcam.com/Scanything/downloads
download lightburn:
lightburnsoftware.com/pages/trial-version-try-before-you-buy
install sheetcam:
sudo sudo dpkg -i package_file.deb
4 years 8 months ago - 4 years 8 months ago #234106 by robertspark
Install RIP for QT PlasmaC
git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
sudo apt install -y dpkg-dev
cd linuxcnc-dev/debian
./configure uspace
cd ..
dpkg-checkbuilddeps
copy BUILD dependencies list to geany and edit to install adding "sudo apt install -y" and removing numbers / brackets.
cd linuxcnc-dev/src
./autogen.sh
./configure --with-realtime=uspace
make -j4
sudo make setuid
source ../scripts/rip-environment
runtests
4 years 8 months ago - 4 years 8 months ago #234107 by robertspark
Set up NativeCAM for Mill, Router and Lathe (Linuxcnc 2.8.2)  {at this time it won't work on Master given it uses python2}
As taken from here:
forum.linuxcnc.org/nativecam/32891-use-n...eb-package-now#94274
Download the attached script and run it
sudo bash /Downloads/ncam_debsetup.txt
As taken from here:
forum.linuxcnc.org/nativecam/39068-nativ...buster-please#182941
curl -s https://packagecloud.io/install/repositories/FernV/NativeCAM/script.deb.sh | sudo bash
4. Open Applications > System > Synaptic Package Manager
5. Navigate to Settings > Repositories
6. Click on the one for packagecloud.io/FernV/NativeCAM/debian/
7. Change the name from buster to stretch in the Distribution field
8. Click OK (Reload when prompted)
9. Close Synaptic Package Manager (if you don't, you probably can't run the next command)
10. Back at your terminal, run this:
sudo apt update
sudo apt upgrade -y
sudo apt install nativecam
11. Then this:
ncam
12. You should see a prompt to create a new directory, and if Axis is open it will ask to restart it.
13. You should answer yes to both.
14. NativeCAM should open in a separate window.
To use with your own inifile, it must first be edited. From a normal user terminal, change directory to the one that contains your inifile Using the command : ncam -i(inifilename) -c('mill' | 'plasma' | 'lathe') will automatically create a backup and modify your file. It will also prepare the sub-directory with needed files and links. If you use axis and -t option it will be embedded in a tab
Navigate to the config files:
cd linuxcnc/config
and run:
ncam -i(inifilename) -c lathe
ncam -i(inifilename) -c mill
ncam -i(inifilename) -c plasma
for tabs, run the following and add in the scripts to the inifile to embed the tabs etc.
ncam --h
4 years 8 months ago #234196 by robertspark
backup / clone HDD to second HDD:
lsblk
CHECK disk order / size!! before running:
sudo dd if=/dev/sda of=/dev/sdb status=progress
verify disk cloned
lsblk
save the following & run as update script:
will need to save as update.sh and run:
chmod 744 update.sh
#!/usr/bin/env bash sudo apt update sudo apt upgrade -y cd linuxcnc-dev git pull cd src ./autogen.sh ./configure --with-realtime=uspace make -j4 sudo make setuid source ../scripts/rip-environment ​​​​​​​runtests
