Not all desktops use lightdm (xfce does), the default gnome/debian desktop use a different file for auto loginhi, i tried to install the image but i got some errors. sudo geany /etc/lightdm/lightdm.conf creates a new file for me because it doesn't exist ... qtpyvcp -h qtpyvcp -i these two commands also return an error and the last pip install git + https: //github.com/kcjengr/qtpyvcp.conversational-gcode.git now i had to stop next time i will try to be more precise however kernel preempt-rt is installed and qt too.
Doesn't have everything, but does have the basics. PB is still missing a comprehensive users-manual.. but it's still in development.i installed probe basic with 2.8.2 xfce buster then converted for my cnc almost everything works but the tool probing says it can't do it with zero feedrate. do you know if there are instructions to switch to probebasic from a configuration with axis?
