This is awesome, almost got it working first try!
Probe basic lathe works right out of the box, editvcp and qtpyvcp are all installed and working properly with no error codes. One thing I did notice though is that in the linuxcnc configuration selector there is no folder for probe basic, but if i choose sim.qtpyvcp, XYZ i can launch right into the probe basic lathe program.
thats where the good news ends though. When launching the xyz config and selecting probe_basic i still get an error code and a crash... Heres the error message:
File "/home/cnc/.local/bin/qtpyvcp", line 33, in <module>
sys.exit(load_entry_point('qtpyvcp===python3-master-174.g2c249709', 'console_scripts', 'qtpyvcp')())
File "/home/cnc/.local/lib/python3.9/site-packages/qtpyvcp/app/__init__.py", line 74, in main
run(opts, None)
File "/home/cnc/.local/lib/python3.9/site-packages/qtpyvcp/app/__init__.py", line 102, in run
load_vcp(opts)
File "/home/cnc/.local/lib/python3.9/site-packages/qtpyvcp/app/launcher.py", line 131, in load_vcp
if _load_vcp_from_entry_point(vcp, opts):
File "/home/cnc/.local/lib/python3.9/site-packages/qtpyvcp/app/launcher.py", line 181, in _load_vcp_from_entry_point
vcp.main(opts)
File "/home/cnc/dev/probe_basic/probe_basic/__init__.py", line 20, in main
qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
File "/home/cnc/.local/lib/python3.9/site-packages/qtpyvcp/__init__.py", line 27, in run_vcp
run(*args, **kwargs)
File "/home/cnc/.local/lib/python3.9/site-packages/qtpyvcp/app/__init__.py", line 129, in run
launch_application(opts, config)
File "/home/cnc/.local/lib/python3.9/site-packages/qtpyvcp/app/launcher.py", line 78, in launch_application
loadWindows(config)
File "/home/cnc/.local/lib/python3.9/site-packages/qtpyvcp/app/launcher.py", line 228, in loadWindows
window = _initialize_object_from_dict(window_dict)
File "/home/cnc/.local/lib/python3.9/site-packages/qtpyvcp/app/launcher.py", line 208, in _initialize_object_from_dict
return obj(*args, **kwargs)
File "/home/cnc/dev/probe_basic/probe_basic/probe_basic.py", line 24, in __init__
super(ProbeBasic, self).__init__(*args, **kwargs)
File "/home/cnc/.local/lib/python3.9/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 43, in __init__
self.loadUi(ui_file)
File "/home/cnc/.local/lib/python3.9/site-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 102, in loadUi
uic.loadUi(ui_file, self)
File "/usr/lib/python3/dist-packages/PyQt5/uic/__init__.py", line 238, in loadUi
return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/loader.py", line 66, in loadUi
return self.parse(filename, resource_suffix)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 1037, in parse
actor(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 828, in createUserInterface
self.traverseWidgetTree(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 806, in traverseWidgetTree
handler(self, child)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 273, in createWidget
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 503, in createLayout
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 546, in handleItem
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 264, in createWidget
self.stack.push(self.setupObject(widget_class, parent, elem))
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 228, in setupObject
obj = self.factory.createQObject(clsname, name, args, is_attribute)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 100, in createQObject
factory = self.findQObjectType(classname)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 125, in findQObjectType
w = module.search(classname)
File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 113, in search
module = __import__(mname, {}, {}, (cls,))
ModuleNotFoundError: No module named 'qtpyvcp_conversational_gcode'
what do i do... im laughing and crying all at once
