- Thank you received: 15
Kinematic model for a 5axis mill with universal (nutating) head
- jschulze
1 year 1 month ago - 1 year 1 month ago #334249
by jschulze
Replied by jschulze on topic Kinematic model for a 5axis mill with universal (nutating) head
Just wanted to say thanks for all the work on this. I just got it working on my machine. I don't have a nutating head, but settings the angle to 90 worked perfectly. Also, since I have 2 c axis I edited the kinematics to pass through an additional W axis for the rotating table.
Last edit: 1 year 1 month ago by jschulze.
The following user(s) said Thank You: besriworld, jpg, Daan96
- Thank you received: 2177
1 year 1 month ago #334253
Replied by Aciera on topic Kinematic model for a 5axis mill with universal (nutating) head
Nice, thanks for reporting back.
- jschulze
1 year 1 month ago #334606
by jschulze
Sorry, for all the questions, but I'm having a bit of trouble with TWP and was hoping I could get some help. TCP is working totally fine and it seems like TWP is partially working, but not quite correctly. Say I issue G68.2 X0Y0Z0 I0J-45K0 and G53.1, the spindle orients itself correctly and I can jog in X and Y, but not Z. Depending on the angles I use I get different axes I can jog. Using G68.3 I can see the plane set in the vismach, but I'm not able to jog at all.
I did mess with the kinematics file to make it work for my machine. TCP works great, so it seems to be working (I added a tandem Y axis and a W axis that isn't involved in the tcp math). Is there anything I could have messed up in the kinematics file? Also, I had to scale some things in the vismach since I'm working in inches. Is there anything in the twp remap files that I would need to scale? Thanks again for all the help.
1 year 1 month ago #334611
Can you post your modified kinemaitics file and your ini file?
- jschulze
1 year 1 month ago #334668
by jschulze
Here's all my files. I've included .ini, .hal, and kinematics comp file.Can you post your modified kinemaitics file and your ini file?
1 year 1 month ago #334676
I've replaced the standard kinematic file with your modified version, added extra joints and changed the config to inches to test in the simulation but I cannot reproduce your jogging issue in TWP mode.
I'm afraid I'm a bit at a loss as to how to troubleshoot this further.
Time to create page: 0.278 seconds
