Kinematic model for a 5axis mill with universal (nutating) head
1 year 1 month ago #334716 by jschulze
I've replaced the standard kinematic file with your modified version, added extra joints and changed the config to inches to test in the simulation but I cannot reproduce your jogging issue in TWP mode.
I'm afraid I'm a bit at a loss as to how to troubleshoot this further.
Thanks so much for checking it out.  I'll play around a bit more and see if there's anything I can find.  I'm just working on a vismach sim of my actual machine, so I'll try it out on there and see if I can replicate it.
1 year 1 month ago #334981 by jschulze
I was able to test this out a bit today and I've figured out it wasn't working because after setting the TWP, the G59 offset made the axis positions outside my soft limits,  I made my soft limits massive and it worked as expected.  If I have G54 zeroed out, then I don't get any values in G59, but my axis position are still outside the soft limits.
I've been digging through the remap.py trying to figure out where the G59 offsets are coming from and I can see where it sets them around line 863, but I'm not sure how it's getting it's value.  It looks like it's passing the G54 offset value to to the twp-helper-comp.twp-ox-in correctly, but after that I'm not sure what to check.  Any idea what I should be looking for?
1 year 1 month ago - 1 year 1 month ago #335007 by Aciera
Ah yes, I'm sorry I have not caught onto this before,  this is expected behavior, which is unavoidable since the motion planner lives in cartesian space and assumes that each joint is aligned with its assigned axis which is no longer the case when the work coordinate system is rotated and thus no longer aligns with the machine coordinate system. Joint limits will be respected but are only triggered at runtime (ie when the joint position violates the limit) and will thus trigger an emergency stop.
It is possible to expand the axis limits when switching to TOOL kinematics and change them back to restrictive values when switching back to other modes but you will have to expand axis limit values when using TWP.
I will need to point this out in the README file.
Last edit: 1 year 1 month ago by Aciera.
The following user(s) said Thank You: jschulze
1 year 1 month ago - 1 year 1 month ago #335011 by Aciera
Note that a similar problem can arise when using TCP:
Whenever a pure rotary move (eg G0 A45 C90) is handled by the motion planner it will not expect a displacement in any linear axis. The TCP kinematic however WILL cause linear displacement to compensate the change in tool orientation and this may cause runtime limit violations that lead to an emergency stop.
1 year 1 month ago #335016 by jschulze
Ok, thanks again for all your work on this, I figured I had just messed something up along the way.  I found your example of the mill turn machine with the switchable soft limits, so I'll try to work on getting that working.
3 months 1 week ago #347873 by kanesl
Hello, I've encountered a similar problem. Where can I find an example of a milling machine with switchable soft limits?
Time to create page: 2.089 seconds
