Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
1 year 6 months ago #325801 by RNJFAB
Changes made. no improvement
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp3s0f0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 78:7b:8a:b4:e1:b9 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.100/32 scope global noprefixroute enp3s0f0
3: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether a8:be:27:c0:1f:18 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.102/24 brd 192.168.0.255 scope global dynamic noprefixroute wlp2s0
valid_lft 6652sec preferred_lft 6652sec
inet6 2401:d006:d001:9301:b2bb:20c1:e292:519/64 scope global dynamic noprefixroute
valid_lft 429sec preferred_lft 429sec
inet6 fe80::5009:8b29:227e:d171/64 scope link noprefixroute
$ linuxcnc
LINUXCNC - 2.9.3-125-g62642dde63
Machine configuration directory is '/home/cnc/linuxcnc/configs/T19'
Machine configuration file is 'T19.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./T19.hal
identityKinematicsSetup: coordinates:XYYZ
Joint 0 ==> Axis X
Joint 1 ==> Axis Y
Joint 2 ==> Axis Y
Joint 3 ==> Axis Z
identityKinematicsSetup: Recommend: kinstype=both
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: ERROR: Could not retrieve hardware address (MAC) of 10.10.10.10: Resource temporarily unavailable
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./T19.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./T19.hal:9: /usr/bin/rtapi_app exited without becoming ready
./T19.hal:9: insmod for hm2_eth failed, returned -1
Running HAL shutdown script
hm2: unloading
LinuxCNC terminated with an error. You can find more information in the log:
/home/cnc/linuxcnc_debug.txt
and
/home/cnc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
1 year 6 months ago #325802 by RNJFAB
All fixed.
new connection setup. And hey presto we are working again.
Thanks Tommylight !!!! life saver
1 year 6 months ago #325803 by tommylight
Yes improvement, not the same error now.
DId you disconnect and reconnect? Or just unplug the LAN cable on one side and plug it back again.
Now it seems the Mesa is off or disconnected, so:
-check the cable is inserted fully on both sides
-check Mesa for red lights (on power on it probably does come on shortly)
-check the Mesa 5V power supply, anything under 4.5V and anything over 5.3V roughly is reason to change the power supply
-use another cable ( i had new out of the box cables not work, kinks and stepping on them will make them useless, etc)
The following user(s) said Thank You: RNJFAB
1 year 6 months ago #325804 by tommylight
1 year 5 months ago #327723 by RNJFAB
SO.......
wifi adaptor died on the mac I'm using for the cnc.
Easy, new Mac.
load linuxCNC 2.9.4.
forget to save a backup of old config (dumb ass !!!)
Spend last night making a whole new config for the machine.
Save a backup on usb this time and place in a safe place.
Having a few glitches, hopefully sorted soon.
1 year 4 months ago #330995 by RNJFAB
Machine is going great and now its time to start adding more.
So firstly - ohmic sensing with the 7i96 board?? i'm sure i have see how this connects, but for the life of me cant work it out. Hookup is simple enough, configuration is what's got me.
Secondly - Air scribe. Hardware is all together. just need to get the post to work for it in sheetcam.
Links to help if you have them please.
& Video's for when you are bored.
www.youtube.com/shorts/XuxqHAO2k5w
Time to create page: 0.185 seconds
